![]() | Home > For Sale & Wanted > [Wanted] TD5 Wing |
130dreamer Member Since: 29 Feb 2008 Location: Romford Posts: 100 ![]() |
Pretty sure I have one for a late TD5, will dig it out at the weekend and get some photos for you.
1989964 Member Since: 11 May 2014 Location: cheltenham Posts: 57 ![]() ![]() ![]() |
Thanks mate i'll keep out an eye
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
I think I’ve a few brand new genuine panels, but pre Td5- you can cut the holes out bigger though?
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11083 ![]() ![]() |
^^^ that means they will fit my Tdi Nick
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Will fit up to end of the 200tdis, 300’s have a larger hole for the “plug” in econoseal type lights and two square holes for the screws, changed them to fit many times just a little work with a rotary burr, drill bit for the screw holes the make the hole square with a small triangle mini file....bobs your mothers brother. Td5 is the same, but has a square hole in behind the facelift headlight surround louvres.
Thanks Nick
