![]() | Home > Maintenance & Modifications > Fitting 240v engine pre heater |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
I've been thinking the same thing. Would be good to have a warmed up car during the cold months.
A quick google search pulled this up: https://www.t7design.co.uk/products/heatin...-pump.html At a guess it just goes inline with the coolant hoses. Shouldn't matter where if it heats up all the coolant. |
Actually, scrap that. You wouldn't want it in-line as it would probably restrict coolant flow. So there's a question, where would be best to t-off for the connections to best avoid just heating half the coolant.
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1661 ![]() ![]() |
fairly easy to fit.we usually fit them into the heater pipe so if you get a split pipe its easy to blank off.
you know a night heater makes better sense bit more work to fit but hot blown air wins every time for me |
