Home > Puma (Tdci) > Another milestone passed
noworries4x4
A big milestone passed today, not many can rack up these hard miles. Bit like Triggers broom, 2 engines early on but this one has done 215thou original gearbox no issues, Ashcroft transfer box 150thou ago and just about to have another one. Rear diff ages ago but front axle all original apart from the welding as are the rear shafts and all hub bearings.
All bushes original but on 3rd set of shocks and second set of HD springs to be expected I run heavy every day.
Just replaced a blown intercooler last weekend.
 If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #741683 21st Nov 2018 11:16pm
Welshsurferdude
Wales
Good to see you are still about in the ladybird 90!
Im only 100k behind you Thumbs Up
seen you out and about twice so u do get about! 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #741685 21st Nov 2018 11:22pm
noworries4x4
I have not been West of the Severn into God's country for ages now. But yes still everywhere else, mainly London Brum and Manchester and anywhere in between.
She is beginning to look a bit rough needs some tlc, the corrosion round the windscreen and alpine windows is getting bad and I had a jackknife trailer last year and the o/s rear corner is a bit bashed, I pulled it out the best I could but defiantly needs a couple of days in the sprayshop.
Most annoying on the appearance side I was on site and they spraying fire proofing onto the steel frame and I have white spots all over it. Picked most of them off but that was February and I am still finding them. Also the Hi-vis striping is fading badly but the reflective is still good. Just got to keep it going another year, roll on 2020. If everything is under control you are not going fast enough.
No Worries 4X4
Post #741689 21st Nov 2018 11:32pm
That's good going. I'm less than 70k behind you but that's an '07, not a '12 plate. Keep up the good work! Thumbs Up
Post #741691 21st Nov 2018 11:45pm
noworries4x4
My old 57plate that the company chairman now has, has 235 on the clock. But that only potters round Bromsgrove these days and the odd towing the boat trip to Fawey Cornwall If everything is under control you are not going fast enough.
No Worries 4X4
Post #741697 22nd Nov 2018 12:41am
Mines a mere baby at 68k at the moment! ๐Ÿ˜‚ I donโ€™t do that many miles though each year. It goes to show the environmental benefits of production and mileage as a lot of ordinary cars are scrapped at about the 100k mark. Then another is made. ____\We|Will|Win/___
____/๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿ‡บ๐Ÿ‡ธ\____
_//*โ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ*\\_
Post #741736 22nd Nov 2018 12:47pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Wow that is a Milestone and a half. Well done!!
Bow down Bow down Bow down Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #741762 22nd Nov 2018 4:30pm
