![]() | Home > Technical > Winter wiper blades |
| Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310
So,
Just had a dump of 10” of snow. The Trico wiper blades immediately iced up and were only partially effective. Anyone have any recommendations for wiper blades for winter? Patrick |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
I’ve tried a few, and LR ones always are better than the rest.
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
make that +1 LR blades
Ok thanks!
We have wipers here specifically for winter that have a rubber shroud around the blade to keep ice from building up. Sadly, dont seem to be any available around here as small as 12”. Ill look for some genuine LR ones. Patrick |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341
I’ve had bad problems with icing of both the conventional and AeroTwin types. Even with the heated screen on had to keep pulling over to remove ice from the blades. 2007 110 TDCi Station Wagon XS
| kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1325
I believe you want 13" blades, not 12 |
| All times are GMT |
