![]() | Home > Off Topic > Mechanical Advice |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1856 ![]() ![]() ![]() |
Sorry I can't help with the figures, but if you undo it with a torque wrench by gradually increasing the setting, you'll know what its set to (approximately) at the moment.
HTH Keith |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
It’s an idea, but I’m not sure it’ll give a reading of any use. There’ll be a lot of stiction to overcome as the bolts haven’t moved in a decade so it’ll likely give a falsely high reading I think. Plus, my torque wrench doesn’t work in reverse. 2007 110 TDCi Station Wagon XS
Bit of a Google search and found this
![]() Found it on these pages http://www.aclassinfo.co.uk/mypage.26.htm |
Thanks JWL. That page is for the previous W168 model. It may or may not be the same, but the two models are substantially different so I wouldn’t like to guess. I ordered the chaps “DVD” in case it has more information on the W169 contained, but for now, still looking for the info. 2007 110 TDCi Station Wagon XS
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
Here you go (from Autodata)
![]() Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Thank you
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
What you don’t just do them up with the 10000000nm impact gun?
Is that five ugga duggas or six?
Wheel nuts are 5 ugga duggas, unless you work at Kwik Fit, then it's 6 2007 110 TDCi Station Wagon XS
