Home > Off Topic > Independent suspension discussion (was 2020 Def)
Cupboard
agentmulder wrote:
Well, in terms of looks, it's much better than the other things that have been presented over the years Thumbs Up
Not my cup of tea, but certainly better.
I don't know much about car manufacturing or the pro and cons of portal axles vs. independent, but for me personally the look of a portal axle is a part of the Defender DNA.
Why did they opt out of them? Old tech? Can't be modernised with all the traction control and so on that we need nowadays?
Defender don't have portals, that's a Unimog thing. Defender have solid (often known as beam) axles.
Independent suspension rides much better and the suspension has a much easier job keeping the tyres on the road because the unsprung weight is much reduced. Properly designed it can work well on an off road vehicle too (Pinzgauer and some Tatra trucks) however on the vast majority of modern vehicles it's not designed to work properly off road. The system the Pinz uses is also completely different to how any normal independent suspension vehicles does it.
Solid axles tend to handle heavy loads better, your ground clearance doesn't change when you load them up, they're much more robust and you don't have a load of exposed CV joints that can be easily damaged. You also maintain ground clearance when driving off road. When an independent suspension wheel goes over a lump, it doesn't pick the diff up in the same was a solid axle vehicle does. That's good for comfort but bad for picking a line.
The reasons I prefer solid axles is that there is less to go wrong. You have far fewer joints and linkages to break, far fewer bushes to wear out, everything is more robust and all the delicate bits are protected inside a lump of steel. On a Defender you have two CV joints and they're inside the metal swivel. On something like a Discovery you have eight CV joints and they're only protected by a flimsy bit of rubber.
For most people, independent suspension is better. For Defenders that get used for Defendering, solid axles are better. If I was building an off road race car I'd definitely have independent suspension. I'm not, I have a remote area plodder.
Post #739658 10th Nov 2018 1:37pm
UtilityTruck
I’ve done 60k miles in mine from new now, apart from tyres and replacing the dampers for higher performing items, nothing in the suspension has yet needed attention. I’ve never had that with any vehicle before, for someone driving on poor roads or off-road personally I think there is a lot to like about solid axles. 2014 Keswick Utility 2.2
Post #739867 11th Nov 2018 4:26pm
Cupboard
And most modern designs of independent suspension don't have much travel either.
Post #739868 11th Nov 2018 4:28pm
hafman
Cupboard wrote:
Properly designed it can work well on an off road vehicle too (Pinzgauer and some Tatra trucks)....
Cough - not forgetting the marvellous Haflinger too
<<<<<<<<<<<<<< Cool Whistle
Post #739877 11th Nov 2018 5:17pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
The UK military replacement for the Defender is the Foxhound and it has independent suspension.
Hopefully LR took some notes.
Post #739912 11th Nov 2018 8:23pm
Slideywindows
Rover were well ahead and experimented with independent suspension 50 years ago.
A friend owns what is believed to be the only surviving test mule, a Series Two.
They concluded that beam axles suited the purpose to which utility Land Rovers would usually be put, and it didn't seem to stop the world's military buying tens of thousands of them while they were still available.
Post #739939 11th Nov 2018 9:43pm
DSC-off
Slideywindows, any chance you could post some photos of your friend's S2?
That sounds really interesting, not seen any pictures or stories in the mags about that.
I'm sure many would like to see it.
Post #739951 11th Nov 2018 10:25pm
Slideywindows
I've seen it a couple of times but never taken any photos as it was not of interest to me.
I think it has independent suspension at the front only now.
He's a long-time member of the 48-53 Register but doesn't court publicity, although I believe it may have been written about in a mag at some time in the past.
Maybe Defender9 will know more, if he reads this.
Post #739957 11th Nov 2018 10:48pm
That S2 only ever had front independent suspension. It was one of six built (3 LWB, 3 SWB|) to evaluate the idea following the introduction of the Austin Gypsy. It obviously didn't catch on.
As far as I know, this is the only survivor and, at one point, was part of the Dunsfold Collection. Darren
Post #739961 11th Nov 2018 11:32pm
DSC-off
Thanks for posting.
It's obviously a major modification. Suspension, steering, transmission and chassis would all need to be re-engineered.
Not surprised it was dropped in the early 1960s.
Post #739964 11th Nov 2018 11:58pm
Cupboard
Yes, the baby Pinz which is confusingly also its father Very Happy
I would love to have a use for one!
Post #739967 12th Nov 2018 12:21am
Ramajama
United States
Yup, The US Military’s go to vehicle has independent suspension. Seems to have worked out pretty well.
Post #739972 12th Nov 2018 4:17am
OsloBlue
The fox hound/ ocelot is supplementing the snatch for frontline service.
The WMIK is being replaced by the jackal 1&2 and the other one
Husky & panther are replacing the Commanders IK and FFR
WMIKs are still retained by second line force protection units and yeomanry reserve regiments. Snatch is still being used for urban riot pacification, and the ten thousand or so wolfs are still being used as runabouts.
I think, but don’t quote me on this, that the reason for independent suspension is due to automatic ZF gearboxes now being used on all of the above vehicles, and that independent suspension is more resistant to IED blasts.
I think all the vehicles in the British army bar the Cr2 are now autos, I think the last manuals that were delivered were the refurbished early jackals that were hand-me-downs from THEM. I'm on IG: https://www.instagram.com/osloblue42/
Post #739984 12th Nov 2018 9:48am
Martin
Site Admin
Discussion split  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #739994 12th Nov 2018 10:27am
Cupboard
The Humvee's had independent suspension since the year dot. Without a doubt it's better for high (or relatively high) speed off road use and it's more comfortable (so less fatiguing) for the occupants.
I guess if you're making an mine resistant vehicle it's also easier to package around a V hull. If you had a full axle under the V you'd end up with a ridiculously tall vehicle but you could mount the suspension on the sides of a V and have something much more sensible.
The fact remains though that if you look at the vehicles on the market, those with independent front suspension (Hilux, D-Max et al) have far more suspension flex in their rear axle than in the front and far more components to wear out and break.
Post #740219 13th Nov 2018 6:00am
