queeg9000
Hello all, I’ve had a search on the forum first, but can’t find any info, has anyone had an issue with a wet drivers seatbelt, with water dripping down the plastic trim behind the drivers door jam, seems odd as the plastic trim sticks out from the side, and the roof lining feels dry?
I’m thinking it could be sun roof, or maybe one of the roof joins?
Any pointers would be great, before I start stripping the roof lining out.
Just found this, seems I'll need a big tube of mastic, and go leak hunting.
You've got to love Landrover when they produce a leaks manual
http://www.landroverweb.com/Pdf-files/Manu...Manual.pdf
Just an update if anyone’s interested, I bought some captain tolley's creeping crack cure, applied it around the sunroof gasket and roof side windows, fingers crossed, no wetness! I’m awaiting the next big downpour.
7th Nov 2018 6:51pm |
