Home > Maintenance & Modifications > Alpine windows leaking
bear100
Found some water in the rear of the defender Evil or Very Mad and have traced it to the two alpine window seals.
Any one had experience with them eg fitting, brand etc
Looking for some tips and tools to use Very Happy 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #738607 4th Nov 2018 6:15pm
dorsetsmith
one these is us-fall for getting rubber insert in place
Alpine Window seal are made for two class sizes 5mm and 4mm Exclamation
Post #738611 4th Nov 2018 6:30pm
donmacn
I did this a couple of months ago, as the seals had quite large cracks in them.
This might be covered in the video, but three things I'll suggest:
1) when you fit the seal, push it well into the rounded 'corners' of the opening, then when you cut the seal, leave it 'long' so that you have to push it back to make it fit (easier to show than describe).
2) you'll likely need some silicone lube spray to get the glass eased into the seal,and some fairly firm pressure from the outside. I made sure the glass was 100% pushed up against one end of the opening, then persuaded it to fit at the other end
(edit - just remembered - I think I used a plastic tyre lever from a bicycle to help ease the outer lip of the seal over the glass, and then finally pushed it into place.)
3) 'belt and braces' - a few weeks later, once I reckoned the silicone lube had dried out, I used a bit of 'Capt Tollley's creeping crack cure' into the top of the seal, and let it work its way along/down. It's very fluid stuff when applied and runs a lot, but it follows any leaks and then dries hard to seal them. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #738814 5th Nov 2018 6:43pm
bear100
Thanks chaps, great video Thumbs Up
Thanks for th tips donmacm Thumbs Up
I think genuine Land Rover is the best approach, going to look up the Tolleys creeping crack cure Thumbs Up 2023 Defender L663 V8
Post #738904 5th Nov 2018 10:51pm
donmacn
No bother - just seen your post on the Duckworth parts section. Hadn't thought your car would be so new. Mine is 1994... perhaps if your car is so much newer, the Capt Tolley's stuff might do the job by itself? Unless the seals are in a particularly bad way. Donald
in the past..
Post #738914 5th Nov 2018 11:27pm
bear100
The seals look really good with no cracks or signs of age or damage.
I might just give the tolleys stuff a try Thumbs Up 2023 Defender L663 V8
Post #739264 7th Nov 2018 9:48pm
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
After having corrosion work around these windows done by the dealer, the passenger would get flooded when coming to a stop. It took a while to figure out that the water was coming in around the windows and then running down the inner gutter. The seals were new and could not see anything from the outside, it was only when looking from the inside that you could see that the seal had a gap, only about 1/2mm, where it joins. I filled it with Sika and no more soaked passengers.
Would recommend Capt. Tolley's, used it on the bulkhead foam seal and roof to windscreen frame. Still leak free after 6 odd months... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #739292 8th Nov 2018 5:59am
