Home > Technical > Diff Lock light not coming on |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
It may be an adjustment issue (switch not screwed far enough into the transfer box front output housing) or it may be that the switch is gummed up. I cant't remember if the switch is pressed or released when the diff is locked, but whichever it is it will make contact when locked.
If you short the switch wires the light should come on. If it doesn't, it's not the switch. |
2nd Nov 2018 7:52pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7682 |
Will take a look. Is the switch a later model for puma or same style as tdi ones with spades on top? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
2nd Nov 2018 8:28pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
Does it come on after a little bit of driving when it’s engaged?
2nd Nov 2018 9:05pm |
no, doesnt come on at all. but diff lock engages in and out smoothly and quickly. Cheers
2nd Nov 2018 10:57pm |
Different connector on late vehicles.
2nd Nov 2018 11:46pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5416 |
Pressing the plunger in on the switch operates the light. The switch can be screwed in further to adjust when it operates. So possibly yoursjust needs adjusting.
3rd Nov 2018 5:38am |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
^^^ what he said
3rd Nov 2018 9:33am |
also make shore wiring is ok right side transfer box i.e earthing on ring tags 6mm bolt sun time get forgotten if box has been out for clutch or output drive shaft
3rd Nov 2018 11:52am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
This is a great site a wealth of knowledgeable people willing to help and give useful information.
130's have feeling's as well you know |
3rd Nov 2018 12:22pm |
Thank you on all, will take a look Monday and report back. Cheers
3rd Nov 2018 5:53pm |
Took it all out today, bridged the wires and dash light works, plunger is defunct on switch, no connection being made so replacement on order. Thank you for help, accessed from top in the end, at least I could see then!
Am I right in thinking the later style ones you just screw in tight and are non height adjustable? Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
9th Nov 2018 12:00am |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 254 |
Hi James,
yes no adjustment on the later ones, if you have to you can swap the thick ali washer for a thinner one, Dave Dave |
9th Nov 2018 9:21am |
cheers Dave,good to hear from you.
parts arrived today, as it happened i needed a thicker washer to avoid light being on all the time with diff in or out. fitted and sorted, thank you all. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
9th Nov 2018 11:16pm |
