Home > Technical > Def 2.2 electronical trouble
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
Concern my def from 2012 and 160.000km.
When I put the headlight on, the "TC" is on on the daschboard and my engine do not stop before I set the headligt off !
Can you help me ?
Thanks
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #738147 2nd Nov 2018 9:09am
Phil VM2.5
Hi,
It is ok know without any explanation
1987 BMW GS80
Post #738491 4th Nov 2018 5:16am
Hi Philipe,
It sounds like an earth fault but it's very difficult to know exactly where the fault lies. I'd start by checking the earth points for the ECU and the main earth straps to the transfer box and engine. Beyond that, it's a case of methodically working through the wiring from the headlight switch backwards until you eliminate the fault. Darren
Post #738505 4th Nov 2018 9:58am
Phil VM2.5
Hi,
Thanks for answer.
I think you are right
1987 BMW GS80
Post #738538 4th Nov 2018 12:40pm
