Home > Puma (Tdci) > HELP NEEDED: 2.4TDCI PUMA
Markez79
Hi,
When setting off from a cold start this evening there was a loss of power followed by a surge and then loss of engine power and coasted to a stop. After that i was able to restart but there was the 'loss of power and surge forwards' through the first 3 gears again. Eventually the issue seemed to clear but just didn't 'feel' right.
Could this be an issue with the battery? I was told it wasn't particularly healthy at my last service.......or something more sinister?
Any help/advice greatly received.
Thanks
Mark
Post #737666 30th Oct 2018 8:34pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
I would say it's the dreaded vcv valve playing up. Plenty of information on here about it. Thumbs Up
Post #737680 30th Oct 2018 8:57pm
Markez79
Many thanks for the feedback, really appreciate it. Is it a big job?
Post #737682 30th Oct 2018 9:03pm
williamthedog
Not really, about half a hours work all going well. Do a search on here it will help you get a better understanding of the job.
Post #737686 30th Oct 2018 9:12pm
Markez79
Thanks again. Iโ€™ve done a search but canโ€™t see whether it is only a prob from cold or whether it is an issue when warmed up.....the fault only occurred this evening but I have a long journey on Saturday that requires the land rover, plus some moderate off roading.....
Post #737712 30th Oct 2018 10:19pm
MK
My faulty vcv was worse when cold Puma 110" SW
Post #737718 30th Oct 2018 10:30pm
Faulty EGR can also causing issues, as can MAF and MAP and VCV. The latter not often showing DTC's if checked.
What status is your EGR, active or blanked? If active have you had any issues with it.
Tryi cleaning your MAP and MAF sensors, this can do no harm either way they may need a clean.
When was the fuel filter last changed?
Are your fuel tank breather pipes in good condition? (Possible fuel contamination if not.)
If all of these things seem okay, then it could well be the VCV as mentioned.
Although I do think many can jump to conclusions that it is, I have had similar symtoms at times year ago but never was the VCV but many other things.
Also check your air filter isn't heavily soiled and also consider trying a fuel additive such as Millers Diesel additive.
If it is the VCV, it should help or at least keep it going okay just for now till you can sort it.
If you can't get your hands on any Millers as soon as you need it, just try some Super diesel instead.
This is assuming you don't use it, you may well already do so.
The clutch switch is another's possible culprit too, but will only show as a DTC if plugged.
If you have access to diagnostics, that's what I would do straight away. ____\We|Will|Win/___
____/๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿ‡บ๐Ÿ‡ธ\____
_//*โ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ*\\_
Post #737721 30th Oct 2018 10:40pm
Markez79
Many thanks Steve - great advice.
I'm trying to get it looked at asap as i need to do a long journey on Saturday that will involve some off-roading.
Unfortunately i don't have a diagnostics tool but with the bad luck I'm having with this vehicle i should probably invest in one.....faulty fuel pump, faulty ABS modulator/Traction Control unit (2.4k to replace Sad ), faulty heater unit, new clutch etc etc.... and i've only had her 18 months.
Thanks again
Mark
Post #737762 31st Oct 2018 9:58am
agentmulder
Kuwait
Yip, EGR stuck in open position will give major loss of power. If it happens again, listen out for the chakka chakka chakka when you turn off the car, if you don't hear it, it's stuck (if that makes no sense search the forum for EGR issues) - keep in mind that if you do hear it, it doesn't mean it's not playing up.
VCV yes certainly. Annoying job, but you'll get there, lots of discussion here regarding it.
MAF/MAP easy to access, may as well give em a clean and check as a matter of course Thumbs Up Solved the bowel problem, working on the consonants...
Post #739610 10th Nov 2018 12:47am
Markez79
It was a faulty EGR! Many thanks for all the advice.
Good excuse for a remap!!
Mark
Post #739623 10th Nov 2018 9:30am
Caterham
yep. welcome to getting an extra 10% MPG too Thumbs Up Thumbs Up
Post #739625 10th Nov 2018 10:22am
EGR failure struck again. Glad you got it sorted and if your anything like me glad to be shot of it. ๐Ÿ‘๐Ÿป ____\We|Will|Win/___
Post #739641 10th Nov 2018 12:21pm
