Home > Technical > Slight grinding sound from the rear in 6th gear |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 280 |
130KM or 80MPH is quite excessive.
19th Nov 2008 1:51pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Sounds like the rear diff to me
19th Nov 2008 2:23pm |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 752 |
It could be the rear propshaft. When the UJ's get worn the prop can vibrate (actually they do this from new but dont usually rumble) causing a rumble sound especially upon decelaration (sounds similer to a bearing going).
Get underneath and have a look at the joints and also check the bolts are tight. Russell. |
19th Nov 2008 3:45pm |
moodyfay Member Since: 10 Nov 2008 Location: Switzerland Posts: 2 |
Thank you Russell,
I will get under the car this weekend for a look. Will keep you posted! Moody |
21st Nov 2008 6:29pm |
felos Member Since: 24 Nov 2008 Location: Athens Posts: 12 |
In my car it was the rear diff.It developed exactly the same problem at approx.5000km and gradualy the noise started to appear at 4th ,5th and 6th gear from 80 to 130 km/h.
The local dealer changed the front diff the transfer box and both propshafts before shorting it out (poor thing). Hope that helps. George NOT A TRANSIT |
26th Nov 2008 7:07pm |
