Home > Maintenance & Modifications > Socket size
dioliahary
Socket size
Just fitted new ignition barrel, the shear bolts are similar to a torx shape but external. Any ideas what socket to use to secure and shear.
 1990 200tdi conversion 90
Post #737296 28th Oct 2018 9:22pm
ickle
a bi - hex ring spanner?
Post #737297 28th Oct 2018 9:24pm
dioliahary
Ta didn’t think of a spanner, will give it a bash 1990 200tdi conversion 90
Post #737303 28th Oct 2018 9:34pm
ickle
No problem, from memory they shear at a very low torque anyway
good luck!
Keith
Post #737312 28th Oct 2018 10:39pm
MartinK
I have a Clarke Torx set, https://www.machinemart.co.uk/p/clarke-trx...it-set-29/
You;re not a million miles away - you can borrow if you need.
Bought it a few years back, don;t use it very often, but mighty-handy to have around Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #737356 29th Oct 2018 11:34am
dioliahary
Thanks for the offer, I swing a bi hex spanner off it and see if it goes, will keep you posted thanks again 1990 200tdi conversion 90
Post #737403 29th Oct 2018 5:35pm
sako243
The inverse of torx are marked E.g. E8, E10 etc. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #737491 29th Oct 2018 10:40pm
dorsetsmith
TORX RING SPANNER Idea
Post #737515 30th Oct 2018 8:20am
