![]() | Home > Maintenance & Modifications > New Battery |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20910 ![]() ![]() |
I don't really think you can beat the original factory spec battery.
They last many many years. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 ![]() |
After some extensive research, I went for a Numax C31-1000 120ah battery.
Was about £109 from www.tanya.co.uk IIRC. |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5129 ![]() ![]() ![]() |
Good battery I have had one fitted for a while now without any problems For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
Busboy Member Since: 23 Jan 2012 Location: West London Posts: 182 ![]() ![]() ![]() |
Thanks guys, Dobby & gilarion does the numax C31 one fit under the seat on a 2011 110, the reason I ask is that when you put your registration number in it comes back with a smaller size battery. Steve
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8318 ![]() ![]() ![]() |
Numax for me, have them either as singles of twin setups on 3xlr, mower, tractor the lot! Used to run them on off roaders too for challenge events. They are good and reliable. Cheers
Have a look at tayna batteries, a good choice and keenly priced. I recently bought one off them. Yuasa 100ah 900cca, £114 delivered
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2360 ![]() ![]() ![]() |
Search 019 type batteries on Tayna, and double check the dimensions.
LR spec is for a 870 cca battery. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2746 ![]() ![]() |
Local motor factors and a tape measure is all you need. Just buy the biggest one that will fit in the space.
Great ideas lads, I'll measure twice and cut (no sorry) buy once
![]() ![]() It looks like the general opinion is for numax which seem to be rated pretty good... Steve |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 803 ![]() ![]() ![]() |
Well, mine has packed up tonight.
Took it off the CTek charger which said it was all A1 and drove it about 7 miles. Parked up and about two hours later whir whiirr clicky clicky. It's a 5 year old Yuasa. It played up a couple of weeks ago hence the CTek charger. I know the output from the alternator is good. More to the point what spec battery is a 300Tdi supposed to have in terms of rating as I can't find it in the haynes book of ... 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
I believe the 300TDi is a bit smaller. The TD5 and newer had a 019 size.
I use the Varta Silver Dynamic (Varta make the original one but that's not necessarily saying much) bought from Tayna. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11031 ![]() ![]() |
After the normal battery replacements that i had over the years, i finally had enough and splashed out on an Odyssey battery and has been spot on and with the extra crank start, it starts up so quick every time, i'm well pleased with it as it has been on since December 2014
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1247 ![]() ![]() ![]() |
Two 019s fit comfortably in a 300Tdi battery box. Got a 110Ah Varta for starting and a second 110Ah Varta leisure for the fridge, windscreen, etc. Each was under £100 and lasting very well. Mind you my previous battery was 19 years old... Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
