![]() | Home > Tdi > Gasket advice |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
I would buy the gaskets individually to ensure I was getting OEM or genuine where affordable. Gasket sets have a habit of having varying quality items within the set and are sometimes missing specific items.
For the head gasket, go MLS (metal) such as Victor Reinz, rather a composite one. Dayco for the timing belt |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5999 ![]() ![]() |
Get your gaskets from Turners would be my advice. They build engines, so know their stuff.
Tommyharris Member Since: 20 Mar 2018 Location: Bristol Posts: 100 ![]() ![]() |
I shall google the above thank you chaps
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
The metal gaskets seem to be better I find. But you can’t really go wrong with Victor Reinz brand very good quality.
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Surprisingly, genuine gaskets were really good value at one time. Don't know if it is still the case.
Gaskets ordered chaps from turners in the end!
with Christmas looming I'm very tempted to complete this mini rebuild with the big turbo and inter cooler I keep seeing on these fancy sites. Still say the 300 is a better engine than my puma though Anyway any tips on anything I can do while head is off is welcome Regards |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
P gasket ,injectors , glow plugs
Yep, have p gasket and glow plugs.
How come injectors?? I have heard a fresh set works wonders but the old gorl was running ok? |
just if there out might be worth getting them check , but if running ok then .
