Home > Maintenance & Modifications > Rotopax - jerry can alternative
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
On our recent trip around Europe we stopped to fill up outside and grab a coffe near Dijon.
Parked up next to several Germans on their BMW touring bikes. The defender had two jerry cans on the roof, one for water, the other it’s fuel, pure precaution.
The bikers showed me their Rotopax on the side their bikes.... smaller, 1 gal units, one each side, told me jerry cans were out of date, and they sent me a link to a distributor in NL.
https://rotopax.com
When I got back, I ordered two plastic 2gal tanks, one for fuel, one for water, as well as a mount, the great thing about these, they are stackable and lock together at their bases, the mounts can be locked as well
Here are mine, on a universal mount, with closed foam rubber which I added, to stop metal to metal rattling and ready to go on the roof rack.
Post #736889 26th Oct 2018 4:51pm
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Those look pretty good. Thumbs Up
Cheers for the link.
I've got quite a few 20L jerry cans and the quality does seem to vary massively.
Post #736891 26th Oct 2018 5:05pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Neat piece of equipment
Post #736898 26th Oct 2018 5:38pm
Coming soon for the new Defender from Powerful UK:
Post #891465 15th Mar 2021 8:29am
familymad
Have seen a few Jeeps stateside with a rotopax set up. They look ace and have some on my adventure bike for longer schleps.
What I would say is that we’ve crossed the pyrenees on the smugglers routes and extensively toured Morocco.... carried water and fuel with us in Sceptre cans and a Jerry.....and never needed it! So they look ace loaded on but I was over prepped with too much heavy liquid! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #891468 15th Mar 2021 8:47am
Neat idea but the front edge doesn't look very pedestrian friendly for the modern era and the modern cossetted mindset.
Post #891473 15th Mar 2021 9:24am
Mo Murphy
More expensive pointless tat for the show and shine overland fraternity.
Overland ! It's not where you go, it's where you appear to go ! 😁
50 Shades of Pennine Grey
Post #891568 15th Mar 2021 3:13pm
This kit now seems to be commercially available with better photos of the mounting arrangements.
Supacat wrote:
Not come across them, so will check out in detail later. Thumbs Up
Looks like someone else is mounting 8020 directly to the roof:
https://www.defender2.net/forum/topic77692.html?highlight=rotopax
Post #901961 8th May 2021 7:43am
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I found them to be quite discreet when underslung on my 110
20ltr version
Post #901976 8th May 2021 10:00am
miker
I like that idea badger, often wish I had a few litres of water onboard for handwashing etc! What was your arrangement for mounting, filling and using the water?
Post #901978 8th May 2021 10:39am
Badger110
I use mine for fuel carrying purposes. The original idea was to use jerry cans as they can be underslung but they're noisy and bulky, these rotopax style carriers are a much better idea.
If you visit here you can see the build thread and how I made up the brackets for it but it's a working process at the moment and could change Wink
Post #902104 9th May 2021 8:35am
Pilgrimmick
Never understood why anyone puts liquids on roof racks or so high up. If overlanding put it in tanks below floor level or at least on the floor, keep the weight low, better stability, better handling and better for your back. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #902136 9th May 2021 10:49am
Grenadier
Mmm, Blackwolf, if you managed to be close enough to the vehicle to hit that leading edge, you'll likely already have had your head transplanted by the massive wing mirrors and your shins broken in two by the side steps. Not to mention some extensive bruising to your body after bouncing down the wings. And then there'd be the unenviable damage to your ego for being run over by a new Def. The physical damage would be reparable, but the damage to your ego (and reputation) would be lifelong. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #902527 11th May 2021 9:19am
But you are making the mistake of applying common sense and reason! Since when did either factor into modern attitudes? Thumbs Up
I think a more likely problem is when a branch or similar gets jammed between the plate and the vehicle (although I suppose that is just as likely to happen with the ladder or the lunchbox).
Post #902546 11th May 2021 12:44pm
