Home > Puma (Tdci) > Code U0428 Invalid data received from steering angle sensor!
West Yorkshire Lofty
Scotland 2015 Defender 90 Puma 2.2 HT Fuji White
Good Evening Gents, has anybody got any suggestions (constructive please) for the above.
Steering Wheel was swapped on my 2014 Defender virtually from new.
Since then you have to tug the steering wheel a quarter turn right which brings on the traction control light before driving off.
If you don’t it drives like the diffs are locked.
Looking at the ECU the above fault is always showing.
Any ideas?
WEST YORKSHIRE LOFTY 2015 90 Keeper
2005 R300 Keeper
2019 XC40 Shopping Trolley
2008 110 XS Utility (Friday Build) Gone!
Post #736405 23rd Oct 2018 8:13pm
Does yours have the DSC button? Models with that feature had a slightly different steering wheel as part of the system so your aftermarket(?) wheel probably isn't compatible. Darren
Post #736415 23rd Oct 2018 9:19pm
Cheers LandRover Anorak, yes mine does have the DSC button!
I must admit none of the aftermarket suppliers mentioned this when purchasing the Moro steering wheel?
Cheers WYL 2015 90 Keeper
2005 R300 Keeper
Post #736449 24th Oct 2018 6:42am
Martin
Site Admin
Does the indicator self cancelling work?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #736463 24th Oct 2018 9:46am
Morning Martin, the indicator cancelling works but it is not 100%.
Seems a bit biased to the right!
2005 R300 Keeper
Post #736600 25th Oct 2018 6:26am
Martin
Site Admin
That'll be it then. The angle sensor is telling the DSC system the car is steering right, however it knows from the wheel sensors and yaw sensor that it isn't.
Have you got the original wheel?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #736650 25th Oct 2018 10:56am
Evening Martin, thanks for the info. Unfortunately the original steering wheel went a long time ago. What your suggestion? Is it time to take it to the garage?
2005 R300 Keeper
Post #736801 25th Oct 2018 10:40pm
Porny
Site Sponsor
Just needs the steering angle sensor calibration done - any good independent will have suitable kit to do this. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #737368 29th Oct 2018 1:08pm
discomog
I was toying with the idea of fitting a Moto Lita and Optimil quick release hub to my Defender 2015MY which is fitted with DSC. Has anyone with a 2015MY fitted the above and more to the point will the DSC still work? (apologies for tagging onto your thread WYF). Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #742414 26th Nov 2018 8:47pm
Sulisuli
I have that fitted to my 2015 with DSC with no problems Thumbs Up discomog 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #742428 26th Nov 2018 9:35pm
discomog
Sulisuli, That's good news, thanks for that. Defender 90XS SW
Morgan Plus 8
Post #742432 26th Nov 2018 9:45pm
