Home > Technical > ABS warning
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
ABS warning
So as my TD5 had an "uncertain" service history (i.e. nothing documented) I've just got it back form having the equivalent of the Land Rover Main Dealer 72000 mile service - and everything was fine.
As it was in there, asked the guy (local garage, not main dealer or LR specialist) to try to find why the ABS light was constantly on (and why the TRC light comes on when ever I hit some potholes).
So he plugs it in and gets:
Pump failure 1 (monitor line)
Pump failure 3 (pump sticking)
Shuttle valve switch failure.
Is this a "ronseal" problem (i.e. exactly what it says), or something else? I was advised elsewhere that anything to do with removing the pump of the ABS should only be done by Land Rover main dealers.
So basically, help??? 2001 TD5 110 DCPU in Bonatti Grey
Post #68675 26th Apr 2011 5:07pm
mse
If it is the pump...prepare yourself for a bill!! Mike
Post #68691 26th Apr 2011 7:10pm
