Home > Technical > Door barrel spinning
Page 2 of 2 <12
tyrannosauROSS
United Kingdom 2006 Defender 110 Td5 CSW Chawton White
Thanks for the link...
In which case... this is not my problem... I think the barrel inside the housing must be corroded to each other.
As the pin I thought was warn down, is actually still there is it used to lock onto the end cap.
I guess order a new set and then see?
Post #735318 17th Oct 2018 3:41pm
dorsetsmith
Thumbs Up
Post #735320 17th Oct 2018 3:42pm
VVS210
I managed to lock my keys in my old 90 & was panicking as I was in the middle of a wood 40 miles from home & my spare keys... my mate told me not to panic & pushed the end of his Hilux key into the lock & simply unlocked the door Shocked
What appears to happen is that over time the tumblers get stuck in the 'key in' position so the barrel can be turned using anything that fits into the lock. Best to get a replacment lock set Thumbs Up
Post #735325 17th Oct 2018 4:26pm
tyrannosauROSS
Ordered from Paddocks.
Three barrels and the ignition jobby.
Thanks for all your help.
Post #735330 17th Oct 2018 4:39pm
VVS210
Don't forget, if you're replacing the ignition lock you'll need a couple of security bolts as well.
Post #735331 17th Oct 2018 4:44pm
tyrannosauROSS
Did this today... door now working! thanks all!
Post #735764 19th Oct 2018 8:24pm
Page 2 of 2 <12
