Home > Td5 > CAT removal
lightning
CAT removal
Yesterday l fitted a decat pipe to my TD5 Defender
I read that this was a worthwhile modification but tbh can’t feel any difference when driving it today. The rest of the exhaust is standard and it’s running a mild remap.
Also it’s had an EGR valve delete kit a while ago.
What’s supposed to be the advantage in removing the CAT? Apart from weight saving!
Post #732943 4th Oct 2018 4:19pm
bankz5152
Faster turbo spool. Ideally need a less restrictive midbox too
Post #732954 4th Oct 2018 5:11pm
miker
Mine's never had a cat, so can't directly compare, but I did notice a difference in how fast the turbo spooled when I swapped my mid box for straight pipe.
Post #732975 4th Oct 2018 8:15pm
Procta
This is going off my 306 HDI which did have a CAT, I removed the thing for the mot, I found the turbo spools a lot quicker and a little more grunt. I later fitted a stainless steal Exhaust which opened the power up too. As bankz5152 says.
I cannot see the point of a CAT on a diesel, for what use it does. I removed it off the 300 TDI and binned the EGR system too.
Also I did block off the EGR on the Peugeot too, which saved the engines inlet. Thumbs Up
It might be worth having the Map tweaked a little bit more, since you have binned CAT off. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #732990 4th Oct 2018 9:23pm
lightning
I must say the turbo lag does seem reduced, for instance when changing gear there’s no delay in pickup like there was before.
The CAT was a Britpart one and l’m not sure it was working anyway.
Post #732991 4th Oct 2018 9:24pm
Procta
Check the exhaust and intercooler pipes for any leaks too, just in case. With the system been more free to flow, it lets the turbo spool quicker. I found the HDIs turbo was louder when it spools.
Also it will go through an mot too, as the cat does square root of Censored all on a diesel. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #732993 4th Oct 2018 9:33pm
lightning
Further update.
Engine revs better and makes more speed on hills than it did before. Not a lot, but definitely better.
Also can change up at around 2,200rpm going up hill where before l had to change at 2,500rpm because there was a short delay for the turbo boost to come back.
Post #733123 5th Oct 2018 4:51pm
Procta
Yeah it will help with the pulling power as the system isn't as restricted. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #733712 8th Oct 2018 9:17pm
