Home > Maintenance & Modifications > Slick shift
shaun1968
United Kingdom 1986 Defender 90 2.5 n/a Diesel HT Eastnor Green
Slick shift
Question is are they really as good as people say, and are they easy to fit, mine will be going on my 90 with LT177 gearbox.
Post #731631 28th Sep 2018 11:09am
geobloke
Yes they are easy to fit. If your gearbox has seen a lot of use budget for a new selector turret as well (FRC7155) as the slot can be quite worn and cause extra slop in the gear stick.
They are... OK! Rolling Eyes
Post #731634 28th Sep 2018 11:27am
Likeomg
I wouldn't bother fitting again...
Post #731678 28th Sep 2018 4:07pm
shaun1968
ah is that because you dont rate them
Post #731692 28th Sep 2018 5:21pm
Likeomg
it didn't make that much difference... my gearbox had 3k miles on it
and it just rattled like crazy until I wrapped it in lots of tape and hammered the gearstick on Whistle
Post #731696 28th Sep 2018 5:41pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Yes. Had mine on for 6 months, need to cover the shaft with tape to stop any vibration... Thumbs Up
Post #731698 28th Sep 2018 5:49pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
2014 plate 90, slick shift been on 2 years, never had any rattling, just put copious amount of good quality general purpose high melting point grease on as per the fitment video and you'll have no issue.
I would not go back to standard gearshift as I much prefer the shorter shift
Post #731704 28th Sep 2018 6:16pm
rallysteve
Presumably you are both referring to the Puma version?
The LT77/R380 one doesnt rattle if it is fitted and adjusted correctly.
Post #731705 28th Sep 2018 6:17pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
I would say it is worth doing on an LT77 box - I find it just makes it a bit less vague Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #731711 28th Sep 2018 6:49pm
shaun1968
Thanks that was what I was hoping to achieve
Post #731712 28th Sep 2018 6:50pm
Mo Murphy
I've got one on an LT77 and it doesn't rattle and has a nicer shorter throw, I'd certainly recommend it for a Land Rover gearbox, but judging by the above its not so suitable for Transits Wink
50 Shades of Pennine Grey
Post #731725 28th Sep 2018 7:51pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
I have an LT77/R380 slickshift for sale. If interested PM me.
Post #731831 29th Sep 2018 10:59am
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
I’ve got one on my Puma and aside from the tape on the gearstick requirement, it’s a world apart from my parents much newer defender which doesn’t have one. North Cumbria Search and Rescue - Team Leader
Post #731846 29th Sep 2018 1:57pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
I fitted mine last week, and its being awkward...
my turret doesn't look warn, but I am having serious issues with gear selection, its been adjust 3 times now (I have watched every video going and followed the instructions to the T, and still had no luck...), and this evening im doing a video call with the guy who makes them...
my issue at present is that I can change up the gears ok but when I change down it doesn't want to engage.
so I will see what happens after my call this evening.
So far when it does want to work it feels good, but that's just not very often at present. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #732207 1st Oct 2018 3:51pm
donmacn
Please report back Adam. You're post above struck a chord with me. I fitted a new turret at the same time as my slick shift.
The box is an Ashcroft R380, but it has been in for about 14 years and done ca. 165k miles.
Like you I tried adjusting it by the book, and got it 'roughly' OK. I ran it like that for several months but then it did get harder to shift down into fourth and second. I assume the new nylon cup in the selector had 'bedded in' causing some marginal extra movement. So at the moment, I'm running the car without the sound deadening insert and the gaiter so that I can do small tweaks 'on the fly'. I think I'm just about there - in the sense that it's at its least bad setting - but it's still not as good as I'd like.
Like yourself, going up the box is OK, unless I'm pushing hard up a hill in 3rd and going to 4th, but trying to come back down again into 4th or 2nd doesn't always go well.
If you get any good stuff from your calls, please pass it on! Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #732287 1st Oct 2018 8:42pm
