![]() | Home > Maintenance & Modifications > Trailer Handbrake catching Spare wheel. |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1909 ![]() ![]() |
DEpending on the details - trailer weight; the tow hitch itself - I can only think of four other things to look at:
use a 'drop plate' between the tow plate and hitch - you might get an extra 5 or 6cms from this; adjust the handbrake lever position or length? - less likely i'd imagine; source a longer drawbar on the trailer, or have an extension fabricated; put the wheel somewhere else for the trips you use the trailer...? Trying to visualise this, it does seem as if the handbrake must be quite high mounted. Maybe some pics would help? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813 ![]() ![]() ![]() |
I have a similar problem with my jockey wheel mast - it's a pain but I just remove it for driving, obviously not an option for you!
I'm considering a NAS step, to move the ball rearwards by the few inches which should make the difference when turning. |
Yeah I can see how this would be a problem. Things that come to mind are;
Altering the position of the trailer hand brake is possible but there is probably a lack of space. Drop plate on the tow ball might give you an extra few inches but forces the trailer to become more nose heavy and reduces the height off the ground too. Put the wheel somewhere else - This is what I would do. The problem as I see it is traditionally you have only a few options; Rear door, roof rack, rear tub or bonnet. The latter is your best option. There are loads of pros and cons relating to the positioning of the spare wheel, unfortunately on a Land Rover as standard it is almost always at the back of the vehicle and slightly to the right, coincidentally directly in-line with the trailer hand brake lever and your problem. Spare wheel positioning;
Bonnet: Love or hate it it's traditional and does get the wheel out of the way, sort of... Rear tub: Great if you have a pickup, not so much if you have seats in the back. Roof rack: Gets wheel out of the way, doesn't impede forward vision, but adds to elevated weight and is tricky to get up and down. Wolf side mount: Not sure how legal this would be in other countries and it does require an extended wing mirror to see around the tyre. Rear wheel carriers: There are many styles to choose from, but what they all have in common is that they do alter the position of the wheel, usually out and up in relation to the standard position. This is where I would start. Ask folks for some photos of their setup, manufacturer, size of wheel etc and you may find the solution. The alternative and it really depends on how often you are towing this particular trailer, is to put a wheel mount on the trailer for those times you are towing. Obviously this would be a real pain in the rear to be swapping back and forth every other day, but once a week/two weeks might be livable. Options here would be to have a modified wheel carrying system whereby you could have a 2" receiver like slot on both the vehicles wheel carrier and also on the trailer. Then it would just be a case of take the securing pin out, slide out the wheel, put on to the trailer, secure in place with pin. Total time 3 minutes. Reverse the procedure when you drop the trailer off. If I were in your position and towing semi-regularly I would be tempted to do this... First port of call though would be photos of other peoples spare wheel setups to see if that is the quickest and easiest solution. |
All depends how much space you need to achieve.
The Alko tow ball has a longer neck so will give slightly more room. Tow ball spacer blocks exist which gives an extra 50 mm. Just ensure you get longer bolts of the correct rating. I can not remember if they are 8.8 or 10.9 bolts Brendan |
How about a Disco II tow ball? The extra few inches length may give you the clearance you need.
![]() Click image to enlarge Some pictures of your existing set up may help. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge A small spacer block and Alko tow ball gives me all the room I need towing a large twin axle caravan. ![]() Click image to enlarge |
andrewlandy Member Since: 07 Feb 2016 Location: Graz Posts: 82 ![]() ![]() ![]() |
Thank you all. Its either a spacer to get me an extra 5cm or remove the wheel.
But ill post some pictures in the next day or so. |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 694 ![]() ![]() ![]() |
A ball and pin hitch like this might help as alternative to spacer?
https://rimmerbros.com/Item--i-LR008244BPD...CJEALw_wcB |
