Home > Maintenance & Modifications > Water proof connectors for spot lamps.
Bluest
Need some new connectors for my 130w halogen spots. The need to be waterproof at they are exposed behind the grille. Any suggestions? 2007 110 TDCi Station Wagon XS
Post #730610 23rd Sep 2018 9:20am
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Try these from Polevolt - https://www.polevolt.co.uk/acatalog/Large-...tml#SID=55 NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #730611 23rd Sep 2018 9:24am
Bluest
They look just the trick Thumbs Up 2007 110 TDCi Station Wagon XS
Post #730618 23rd Sep 2018 11:02am
leeds
They are Superseal connectors. Can get a proper crimping tool for eco and superseal connectors. Can be crimped with needle pliers etc with care. However if badly crimped or distorted then will not fit into the plastic housing properly.
Brendan
Post #730638 23rd Sep 2018 12:45pm
I did all of my Econoseal connectors with needle nose pliers, mainly because haveca better feel of how tight they are and for precision. I’ve never had an issues with any at all.
For high current loads the smaller Anderson connectors and rubber boots are extremely good if fitted properly. The joint between the two plugs can be sealed using one wind of high quality electrical tape with a tear off tab. Then you can rapidly remove if needed.
And use the Anderson dust caps as a temporary protection. But I do like to go overkill on such things for maximum voltage and with low losses.
Those connectors above should be fine though for the intended application. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #730646 23rd Sep 2018 1:23pm
MadTom
Do you really need connectors there? How often do you plan to disconnect the connector? These connectors are fine, but for remove "once in five years", standard (spade, faston or how it is called) connector and some heatshrink tubing with glue inside is also good. Cheap and easy to mount, and very small. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #730709 23rd Sep 2018 7:10pm
Bluest
Connectors definitely needed. I change my mind on front lighting setup about twice a day. I’ve had the grille off more times than I can count. Current spots are only interim items so will get replaced at some point. 2007 110 TDCi Station Wagon XS
Post #730745 23rd Sep 2018 8:48pm
