Home > Maintenance & Modifications > Fitting Croytec Anodized window blocks
Lorryman100
I have been debating whether or not to get these for a while now and after washing the landy on Tuesday and found one of the window blocks to be corroded I decided to splash out the £115 (inc del) to get them.
One of the original window blocks is ok, where the other has started to corrode:
The black anodized window blocks from Croytec are solid and well machined with a lovely finish:
So the first thing to do was remove the old window block on the drivers side. This is held in place by three bolts accessed through the cab:
Once removed you have to carefully pull off the two gaskets from the original block:
Then it is just a case of refitting the new block and bolts, I also took the opportunity to coat the bolts in grease:
You then just repeat everything for the other side. All in it took about 20 mins to do and is not difficult. I think they look good in black as they match the black on the Landy.
Post #68187 21st Apr 2011 12:19pm
BigRuss
They look really good Thumbs Up Russell
2011MY 110 XS USW Black
Post #68189 21st Apr 2011 12:39pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
You could get your original ones powder coated black.
Post #68190 21st Apr 2011 12:47pm
Zagato
Look great Thumbs Up
Post #68192 21st Apr 2011 1:25pm
The Boy
Well nice Thumbs Up
Post #68196 21st Apr 2011 2:27pm
Lorryman100
Good idea Matt, I'm going to put a set of alloys in for blasting anyway so will get these done as well. Then get them all powder coated grey Mr. Green
Post #68206 21st Apr 2011 4:26pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
bit steep at £115 though
Post #68315 22nd Apr 2011 2:21pm
Lorryman100
Not in my opinion as they are a quality product which will outlast LR replacements. Each to their own IMHO Thumbs Up
Post #68317 22nd Apr 2011 3:07pm
mse
I too think £115 is borderline expensive.
Interested to see what caused them to corrode - is the back of the one thats bad damaged? Mike
Post #68320 22nd Apr 2011 4:37pm
fekete
They look nice Brian Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #68322 22nd Apr 2011 6:13pm
WarPig
They look great, im tempted to buy some myself. Took mine off my 15 year old 300tdi other day to replace. Insides were particularly bad
Post #68326 22nd Apr 2011 6:54pm
RED-DOT
Jeeze, what a price for a part that does nothing and i thought Defenders had a 6 year corrosion warrantee? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #68327 22nd Apr 2011 7:03pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
I was considering these too, but the croytec website does not have a price listed for them, a reason for this i guess!
The originals are £12 a side, plus about £1 for the gasket, think i may buy the original ones and poweder coat them as the drivers side on my truck is shot.
I would pay upto £60 for them, shame as they look really good.
The door hinges are the same I guess, but well outside my pocket.
Post #68330 22nd Apr 2011 7:57pm
Lorryman100
Well RD, I'm here to show that not all jocks are tightwads. Whistle Laughing And it's a pain in the arse to keep taking the landy in for minor niggles, especially when the sh**ty replacements will only last another 18 months. Also I was led to beleive that the corrosion warranty is for perferation, not surface rust Question
Mike, the paint started peeling from the top and from under the gasket at the top of the block. You can see what I mean in the 5th picture as it shows the paint blistering with a small amount of rust on the inside Thumbs Up
Next thing will be 4x door hinges from Croytec finished anodized black to match everything else Mr. Green
Post #68343 23rd Apr 2011 2:06am
Zagato
Red Dot, you can find the warranty particulars on LR's own site. It explains the difference between the 3 & 6 year paint & anti corrosion warranties!
These hinges eventually corrode on all Defenders and no manner of scraping back, treating and respraying with powder coat or otherwise will sort the issue out. I am pretty frugal with my dosh Whistle but to pay £115 to get the problem resolved for good if they are looked after is a blessing Thumbs Up I suppose it depends on how long you are going to keep the vehicle.
I was going to get a pair in silver BUT the colour doesn't quite match and the black ones do look good matching the other black items - good idea Lorryman Thumbs Up Have you got any pics of your Landy which show it in full - couldn't find any.....looks nice.
Chris
Post #68345 23rd Apr 2011 7:32am
