Home > Puma (Tdci) > puma rear side sliding window removal
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
all i have found is how to pull the side rear SW windows on non-pumas. one reference to the pumas being different, but not how. my gull wing windows arrived from front runner.
anyone know?
Post #727087 4th Sep 2018 2:10am
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
Normally it's just a case of pulling the rubber filler strip out then drilling the rivets. I've not idea what would be different about a Puma though
this is quite a good video on how to do it... granted on a non-Puma. The theory should be the same though
 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
Post #727088 4th Sep 2018 5:25am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Never had to remove one, but I think the Puma side windows are bonded in and are difficult to remove. I read somewhere that you had to use heat and fine nylon string to break the seal.
Certain others will be along with more details.
Post #727099 4th Sep 2018 8:20am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Jup, they are glued/kitted.
You have to use a string saw to get them out.
Not to difficult you just have to take your time. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #727103 4th Sep 2018 8:35am
zsd-puma
a windscreen removal knife probably does them too.
Post #727115 4th Sep 2018 10:37am
big110
Well interior trim is off but what a PAIN to break the silicone seal. 1/2 hour just to get the bottom one done.
Post #729851 18th Sep 2018 11:31pm
