![]() | Home > Puma (Tdci) > Uprated Radiator for 2.4tdci Wanted |
Bergos Member Since: 08 Aug 2015 Location: Somewhere in Portugal Posts: 95 ![]() ![]() ![]() |
The short answer is this:
https://www.allisport.com/shop/performance...placement/ But... Are you sure you need a new radiator? If your Puma is overheating there is a bunch of stuff to check before you spend your money on a new radiator. Bergos LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Maybe try Pete at Bell Autos he might have stock of them?
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Hi
I'm in the same boat (change the radiator) but still not convinced about it (need to do a compression test) So, quite interested in know your experience SMB when you have the new installed. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Hi Eduardo,
Will do, but it may take a while unless Allisport can improve their quoted deliveries🤞 |
