![]() | Home > Puma (Tdci) > clutch rattle |
Dean Watson Member Since: 17 Jul 2011 Location: Derby Posts: 265 ![]() ![]() ![]() |
thanks for all the help!
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346 ![]() ![]() ![]() |
![]() I think I sent you PM......I see no one else has bothered to help. |
Well ok, you said you were prepared to travel. I got my done by Derek Linch haulage in Kent.....
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2492 ![]() ![]() ![]() |
For the clutch, probably clutchfix or from the transit 4x4; the latter probably being a bit noisier at idle as does not have the central dampering hub. Look for dgardel forum member's advice for the transit clutch.
I would go for the ashcroft output kit if I would live in the uk. I'm actually sourcing a local solution for my output shaft. Puma 110" SW ............................................................. Earth first. Other planets later |
Go for a Clutchfix. Now since yours is a 2011 Defender the chances are you have not got the uprated slave cylinder so will need the valve and adaptor. Available HERE
Brendan |
What is wrong (now!) with the std slave cylinder? Puma 110" SW
hi thanks for the replies , got the Pm from Wayne thanks for that , just looking now for recommendations for someone to fit the parts.
Cheers |
The exact reason why LR did an uprated clutch I am unsure about. Apparently latest clutch slave cylinder gives a lighter pedal.
Think the VIN number fiited from is VIN FA459934 however I need to verify that. Brendan. |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
Nothing wrong with it but Brendan is right you do need to change it for the new type as I don't think you can actually buy the old type any more - and you'd be silly not to change it whilst you're in there! ![]() Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
The new type supposedly give a lighter pedal feel I think, though the difference is marginal.
