![]() | Home > Puma (Tdci) > Tdci Downpipe |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17990 ![]() ![]() ![]() |
A couple of the photos in this brochure mkight be of use (RHS of 2.4 powerpack, underside view of 110).
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2782 ![]() ![]() |
Thanks. I had seen those and the underside photo in particular is useful but would benefit from being a bit closer to give the detail I'm after.
I think my biggest issue will be that I'm using the 300Tdi gearbox crossmember which has the crossmember bit itself further back than the Tdci/Td5 one. This may mean that the exhaust wants to occupy the same space just under the front output housing of the transfer box, so it might need to be a bit further forward. This could, if I'm unlucky, cause problems for articulation of the front propshaft. Nothing that an afternoon with a welder can't fix of course but the less fabrication I have to do the better. I'll pick an aftermarket decat pipe up and have a play as they're fairly cheap, but photos of that crucial area would help if anybody has some. |
lost gringo Member Since: 28 May 2018 Location: santiago Posts: 18 ![]() ![]() ![]() |
looking at the parts manual the difference between 90,110,130 seems to be the length of the front pipe from muffler with the crossover being the same. so each model has a different muffer so to speak.
