![]() | Home > Puma (Tdci) > Hand brake warning light |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Happens to me also.
Finally was a problem in the parkin brake sensor connection. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
![]() ![]() ![]() This time was a fault of the dealers when they change the broken clutch... Happens to you also? ![]() ![]() ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
No new clutch as yet but its recently been serviced
Fjord Member Since: 03 Jul 2009 Location: West Highlands Posts: 14 ![]() ![]() ![]() |
Same problem with mine after being serviced a couple of weeks ago. I'll get the dealer to see to it next week when it's in for the handbrake safety re-call work. Any of you guy's know if the handbrake sensor is easily adjusted and it's location. Is it somewhere under the rubber gaiter or is it external ? Just in case it happens in future as it's a pain in the arse taking it back to the dealers for such a trivial matter. Cheers |
The switch for the warning light is in the gaiter mine is as slack as a bag of nuts , had a mess with it but it might be faulty
Cheers Mick
![]() Looks like it's needs replacing as it's more on than off after checking it. |
