![]() | Home > Puma (Tdci) > Help - Issue when going 90km/hr |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 453 ![]() ![]() ![]() |
Have you checked the turbo. Sounds like the actuator could not be working properly.
I had a similar problem and found the vanes were sticking when it was hot. It tended to happen when it was hot. A switch off and restart would usually fix it |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17918 ![]() ![]() ![]() |
Also check the wiring harness to the turbo for chafing damage all the way from ECM to turbo.
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
There was a Land Rover Technical Service Bulletin adressing the P0234 Turbo overboost condition:
https://forum.lrch.nl/download/file.php?id=5277 About the P1103 error code: Check the air inlet system for leaks or blockage. Check MAF sensor or replace the sensor if needed. Clear fault codes and check if all is good now. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
chris.jones Member Since: 20 Dec 2013 Location: Santiago Posts: 2 ![]() ![]() ![]() |
Thanks for all responses.
I changed the MAF sensor and clear the codes. Drove this afternoon and worked fine. Also before doing the changeI realized that some smoke was coming out of the exhaust, and after changing the MAF sensor the smoke was also gone. I believe all was caused by a malfunctioning MAF sensor, causing the turbo to go crazy and bad combustion in the engine. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20951 ![]() ![]() |
You can clean the MAP and MAF sensors, if you've changed the MAF I'd recommend you clean the MAP.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
