Home > Puma (Tdci) > Faux RHS vent blanking plate
NMBRPL8
Australia
Is there a reason why the 2.2 litre Defender has a blanking plate for the faux vent on the front right wing panel, but the 2.4 has a grill with holes ?
Wouldn't cooling be improved if the 2.2 vent could breathe? Why did they introduce this part?
Post #717591 14th Jul 2018 2:19am
zsd-puma
My 2.4 doesn't have holes. It's just the blank they used for all previous models.
If you've seen one with a grille, My guess is someone has added the vent grille from a LHD vehicle at some point.
Post #717599 14th Jul 2018 7:24am
Hal
My 2.4 isnt a grill either. But ive rivetted a blanking plate underneath for well known security reasons.
Post #717606 14th Jul 2018 8:11am
The standard arrangement is for the drivers side to be fitted with a non-perforated blank plate. It's obviously to allow for the heater to be fitted on either side to accommodate left and right hand drive. If you've got one fitted with a grill on the drivers side then, as already mentioned, it's been fitted by a previous owner.
I've never understood why people fit grills in place of the blanking plate, let alone the 'air ram' ones such as KBX. All it does is allow rain to get in where it shouldn't Confused Darren
Post #717623 14th Jul 2018 9:43am
The rain on a KBX opposite to the heater / fan intake just goes directly onto the plastic inner arch below and then runs straight onto the ground.
Even then it'd be very little compared to a factory 'open' vent due to design and engine warmth soon dries everything up in the vicinity.
There is nowhere it can go that causes any issues. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #717632 14th Jul 2018 10:48am
NMBRPL8
Australia
Thanks for the input. The 2.4 I was going by was an unmodified SVX so perhaps specific to that model.
Post #717642 14th Jul 2018 12:16pm
It really shouldn't be. That wasn't a part that was changed on the SVX.
My point was, Steve, that having an open vent on the drivers side, of whatever design, serves no purpose. Darren
Post #717711 14th Jul 2018 7:42pm
zsd-puma
To be honest I doubt it makes much difference in terms of rain. There's a great big gap with no seal where the bonnet meets the wing, so as much if not more water will run in there and it leads straight to the same place the vent does.
That being said there's still no point fitting a grille on both sides.
Post #717718 14th Jul 2018 8:18pm
Julie
Re: Faux RHS vent blanking plate
My early 2.2 has the snorkel and a grill. Like the 2.4. Strange... Cow
Post #717924 15th Jul 2018 9:33pm
sagarmin
Spain 2007 Defender 110 Puma 2.4 SW Chawton White
Hi! I bought two aluminum Optimill wingtop grill vents for my Defender 2007 110 (LHD) before realizing the left vent is a blanking plate and not a real vent. I've been thinking of installing the vent where the blanking plate was anyway just for aesthetic purposes - is this advisable or not, as rain and dirt organic matter will then be able to fall into that space underneath? Thanks.
Post #1074478 1st Sep 2025 9:41am
