Home > Puma (Tdci) > Help- Puma 2.4 doesn't start
RubenCoelho
2007 Defender 110 Puma 2.4 SW Belize Green
Greetings family,
Puma does not start, walked all day and I stopped normally, after 3 minutes no longer accepts starts.
I turned off the fuel input all the way in and I made gravity isolating the tank but still nothing
I added the video for more details.
Thans in advanced.
Post #716993 10th Jul 2018 11:02am
Check underseay relays are secure and the the earths and battery clamps are tight ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #716995 10th Jul 2018 11:05am
RubenCoelho
As long as the battery is good, I even changed it for another one.
Now which relays and earthing terminals do you mean? You have to add an image or pass the exact position for me to check.
Thanks in advanced.
Post #716997 10th Jul 2018 11:12am
Eduardo
Hi Ruben
Some questions:
Do you have ligths or is completely dead?
Check the main fuse located nearp the positive terminal of the battery
Check the terminals of the battery are well clamped (both, positive and negative) as C90S said
Check the fuse case that are in the seat box (rigth side) and see if one is burnt
Check all the fuses in the fuse box located below the steering wheel.
Try with that first.
Cheers! Eduardo
Post #717109 10th Jul 2018 11:54pm
RubenCoelho
Hi Eduardo,
Answering your questions.
Do you have ligths or are you completely dead?
I have lights yes, if you notice the above post I added a video.
I add one more photo of the panel.
Check the main fuse located near the positive terminal of the battery
Verified. Add the picture.
Verified. So much that I even changed for a new battery.
Check the fuse that is in the seat (rigth side) and see if one is burnt
Verified. No fuse burned.
thanks.
Post #717135 11th Jul 2018 8:36am
Eduardo
Hi Ruben,
Did you check it with a tester?
I Realize in the video that the key doesnt have the alarm FOB.
Do you have it with you when you try to start it? If not the alarm system will not allow you start the car.
Put the FOB in the key ring and try again.
Check this first.
If not I will suspect othat you havce some truoble in the fuel line.
regards Eduardo
Post #717514 13th Jul 2018 3:33pm
