![]() | Home > Off Topic > Any electronics gurus out there? |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
OK, I suspect this is not really one that you need to be an electronics 'guru' for, but what I know about electronic circuits, you could scribe on a gnat's danglies.
As some of you know, my 'other' hobby is historic car racing. One of the issues I have is that it's sometimes difficult to see pit boards for driver changes, especially in endurance races at night. So, my brainwave, was to have a remote controlled LED 'come into pits' light, which can be switched on from the pit wall, as the car comes past. I found one of the following at Maplin, which has a (in theory) 70m range, and can switch on and off one circuit. Since this needs 12v for power, my aim is to run it from a cigarette lighter plug, to enable it to be moved from car to car. http://www.quasaruk.co.uk/acatalog/Remote_Control_Systems.html My only issue is how to wire up the circuit to the LED warning lamp. What resistor should I be using with a 5mm super-bright LED, and how do I wire it up? Any help, much appreciated!! ![]() ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6720 ![]() ![]() ![]() |
This'll cost you a spin in the Giulietta
![]() Once the unit is powered from 12V, it basically operates as a remote controlled switch - so you can switch pretty much anything. Have you got an LED in mind? I would go for the biggest, most super ultra mega bright you can find so you spot it! ![]() You need the Forward Voltage and Forward Current from the LED spec, and plug them into this (assuming you'd use the car's 12V to power the LED too): R = 1000 * [12 - Fwd Voltage] ------------------------- Forward Current in mA This should give you a number between 100 and 1000 if you've plugged the right numbers in ![]() Alternatively you can get 12V LEDs, which have the resistor built in ![]() ![]() ![]() |
Also, I presume you're looking at the QS1 from that page? In any case they all say they are 30m range
![]() Try this for a wiring diagram: ![]() ![]() ![]() |
Thanks, Martin, you're a star!
![]() ![]() Hadn't even thought about 12V LEDs but am now thinking of using one of these: http://www.vehicle-wiring-products.eu/VWP-...ledgwl.jpg Will get to it, and let you know the results. And I may be doing a track day at Goodwood later in the season. If I do, you're welcome to a few laps! ![]() ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
