![]() | Home > Puma (Tdci) > vacuum pump oil leak |
TD5 vacuum pump is part of DC Alt or you referring to ford 2.4 engine vacuum pump
ampstp Member Since: 04 Jul 2018 Location: kington Posts: 9 ![]() ![]() ![]() |
2.4 tdci brake vacuum pump
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 1000 ![]() ![]() ![]() |
Best to post this question in the proper forum...
![]() 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
Moved
Roverrobbie Member Since: 06 Feb 2016 Location: Orkney Posts: 17 ![]() ![]() |
I replaced the vacuum pump recently and it has been ok so far. Do you have a part number and supplier for these viton seals incase my new pump fails?
Hi Roverrobbie
20x32x7mm SKF Viton Oil Seal Double Lip R23/TC Viton Rubber Stainless Steel Garter Spring Amazon, ebay or any seal specialist, other makes are propably available but SKF is quality I fitted above seal to the vehicle's original leaky pump about 18 months and 20K miles ago, after a brand new replacement pump failed leaky after 8k miles in under a year. I then modified the new pump with the same seal for a spare, but haven't needed yet and dont think I will for a long time. I am assumming that when this seal is installed, the seal lips are running on a new bit of shaft because the failed pump always has a deep groove in the shaft cut by the useless original seal when it goes brittle! You will need a puller to get the drive pulley off and dont forget to re-fit the circlip |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
Perfect information, will be on my list for preventive actions!^ ![]() |
