![]() | Home > Maintenance & Modifications > brake hoses |
josefk Member Since: 09 Jun 2014 Location: lincolnshire Posts: 113 ![]() ![]() ![]() |
hi,
i'm struggling a bit to identify brake hose part numbers - i need the info of the standard hoses to find in turn equivalent braided brake hoses - there seems to be a lack of obviously identified braided hoses suitable for a 2.2tdci 90 with ABS. would anyone know if i have the correct numbers here: rear center left : SHB101430 rear center right: SHB101370 front either: NRC7874 with this confirmation i think i can then identify if these will be suitable [or not]: http://auto.helperformance.com/land-rover-...59807-2006 cheers all |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20959 ![]() ![]() |
Try having a look here:
https://www.landroverworkshop.com/diagrams...oses-pipes ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
If you want braided hoses made up give llama 4x4 a call. He should be able to make the hoses up for you
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
+1 for Llama a defender from 1984 pretending to be a puma with a touch of Range Rover
