![]() | Home > Technical > Big problem |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
sorry to hear about your problem. i have no idea as such on a defender but i had similar problem some time ago when hot under load and it was fuel starvation.
just a thought. good luck BM52 |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
What winch have you got fitted and where is your numberplate located
is the fuel filter clean ? 2.4 90 XS
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Not good Mike,,
Does sound like fuel related (under load, and up hill) Presuming the temp gauge is reading normal ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
All I can suggest is the basics:
Fuel filter, spray some contact cleaner in the ECU plug, the fuel rail plug, the throttle potentiometer plug and the MAF plug. And also check the wiring on those. With the temp going up though I'd look at the cooling mainly - is your radiator full of mud and dust? Is it obstructed by your bumper? Does having the heater inside on full blast make a difference? Is the system pressurising? Is there an airlock? Enough coolant? Is the turbo on a Tdci water cooled? Have you had a remap? |
Cheers guys. Seems it was fuel related and is pretty much ok now. Having said that (Andrew) there is also the possibility of radiator as it got better into the night. Plate is on the front attached to the fairlead, might remove it in a bit. However, the temperature gauge never moved and there are no fault codes?
Stephen, no remap, no mud in rad. Coolant level ok.
Oh and I managed to leave a bottle of coolant on the boat but I guess I could just use water if neccessary
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2502 ![]() ![]() ![]() |
The temp gauge does not move up from the middle position between ca. 85 and 110ºC or so. Can u check the actual temp while driving? Puma 110" SW
Could do yes. Just means driving with the obd key in place
The standard Land Rover temperature gauge is about as much use as a chocolate fireguard. Coolant boils at between 106-120C dependent on concentration and pressure. The standard Land Rover temp gauge does not shift from normal position until 96C has been reached. On our overland vehicle we have an Engine watchdog fitted. I have set mine to give an audible alarm at 96C well below the boiling point of plain water under normal pressure. It has saved us from a serious problem once when I had a pinhole rubbed into top of rad. It rarely triggers and if it does I just watch the world go by for 20 minutes. Will be fitting one to the Puma as well. Sorry Mike can not help you with your particular problems. Brendan |
Cheers Bren.
If I take off the battery leads to reset the ecu can someone please remind me how to input the eka code? |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
Hi Mike,
How hot is it where you are driving? I wonder how hot your intake temperature is getting to ? ( not engine temp ) There maybe something in the ecu which reduces power if the temp gets too hot. Just another thought. Steve |
Thanks again for all the replies, just found some wifi in zagora. Took off the tanks and the pick up was clogged. All ok now.
