Home > Maintenance & Modifications > Heated Windscreen Loom Route
adeparko
Scotland 2007 Defender 90 Td5 HT Sumatra Black
Can anyone please help on the routing of the loom for a heated screen?
I’ve got the kit from Mobile Centre which looks great but I’m struggling on how the loom gets from the battery box to the dash?
Any help would be great
Thanks
Ade
Post #713157 19th Jun 2018 1:09pm
bubble
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
is it a puma or 200-300 tai
Post #713235 19th Jun 2018 6:28pm
bubble
if its a puma out of battery box under floor and bring wiring back though holes were heater box is you have to remove brake to do this not as easy as old type defenders
or drill hole in corner of battery box run cables under floor mat and come up to centre with with wiring then connect back of radio loom
300 tdi loom or older out of battery box under floor the over gear box bring wiring back though back of clocks and connect up behind clocks only one wire to connect yellow
Post #713237 19th Jun 2018 6:36pm
