Home > For Sale & Wanted > [For Sale] Roof Tent 3 man / Person
Stupots1968
England 2015 Defender 90 Puma 2.2 HT Montalcino Red
Used only 4 times in past year, stored in garage over winter.
Annex never used.
Picture is off tent supplier website for Illustration purposes.
price £900 ovno
3 man tent
Foam Mattress with cover
Zip on annex ( picture of tent is from direct 4x4 website)
Ground Sheet
Waterproof travel cover
Ladder
Window Hinges
Roof top fixings
Straps and ties
All fixings needed
Full instructions
Roof Tent Features:
The main section of the tent is made from expedition quality, oxford nylon material. There is a waterproof cover cover over the top of the tent to give it extra protection from the elements. The tent folds out neatly using a series of aluminium tubular loops. One of the loops mounts in place to form an entrance cover so you can go in and out but still be under cover. The mattress is is a 3 inch thick, high density foam with a green cotton cover (washable). There are 3 windows on the other sides of the tent. The windows also have an insect screen zipped in which can also be fully opened or not. The windows are firmly propped open with stainless steel rods. the base of the tent is aluminium coated ABS plastic. All the material is double stitched and the zips are wide heavy duty. The PVC outer cover is fastened in place with thick Velcro and 2 securing straps.
Annex Features:
One of the best features of the tent system is the zip on annex at the base of the tent. This provides a whole other room, which can be used to keep a kitchen, your wet or dirty clothing or other items. You even have enough room to sleep 2 children in there. The main annex is made from the same durable and waterproof material that is on the outer of the tent. There is 1 entrance and 2 windows to either side, these all have anti insect netting integrated, so you can have the option of fully opened, open with anti insect netting or fully closed. The rear of the annex has a single zipped exit into the vehicle, this means you can access vehicle without going outside. The Ladder forms the support for the tent and sits within the annex. It has a fully waterproof PVC groundsheet on the floor which is zipped together with the main annex. The material is double stitched and has built in straps to connect the guide ropes to.
Post #712684 16th Jun 2018 9:22pm
