Home > Maintenance & Modifications > Registration Plate
v40mav
Registration Plate
Just fitted the new winch & bumper - but come across the same old issue of where to mount the registration plate.
I still need to change the rope and fairlead to synthetic so could make up a couple a brackets there but still not sure I will like it there -
2 Spots also to go on the A frame so can't put on the grill .........
What is the legal position if I put this on the front of the roof rack ? Is this allowed and legal ?
 Defender 110 County SW
Disco 3 HSE
Freelander 2 HSE - SOLD going back to a car
www.lothian4x4response.org
Post #66334 6th Apr 2011 6:36am
Thats were mine is the Roof Rack
Its a debateable point but generally accepted better than a direct failure to display fine
Post #66336 6th Apr 2011 7:30am
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
I recall AndrewS answering this one whilst off topic on another subject. His reply was:
AndrewS wrote:
Just had a chat with some V nice traffic police at the OK Dinner on the A49 in Leominster. ... I pointed out the number plate on the front of my rack and they said that its probably not in the correct place but is clearly visible, they could understand why its up there as there is no decent place to mount it on the bumper and is out of harms way. As far as they (3) are concerned they would not bother pulling me for it.
 Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #66364 6th Apr 2011 1:44pm
I don't think there is anything illegal about putting the number plate on the front of the roofrack provided that the plate is in a vertical plane facing the front. I *think* that the main legal requirement for front plates (which is less specific than that for rears) says something along the lines that they must be clearly visible to someone standing 20 or so metres in front of the vehicle. There isn't, as far as i know, a restriction on height, but they must of course be the proscribed type (correct colour, font, and spacing). It is generally accepted, though not as far as I know established by case law, that adhesive number plates are not legal, not least because they tend to be stuck on the leading edge of the bonnet where they face more upwards than forwards.
When I fitted my winch I had the same dilemma as you, except I don't have a roof rack. In the end I fixed mine to the front grill with cable ties; it looks fine, doesn't cause any airflow problems and is well out of harm's way. This wouldn't be an option if I had extra lights fitted therem of course. Incidentally I did the same with my winch-equipped Disco 2 - cable ties to grill.
Post #66376 6th Apr 2011 2:44pm
I ran for 2 years WITHOUT a front plate on my green 90
https://picasaweb.google.com/letsoffroad/S...2291519906
I thought, I'd give it the ''it must of fell off, Officer'' attitude ... Truth is I was never stopped once !
Post #66378 6th Apr 2011 2:51pm
Post #66379 6th Apr 2011 2:54pm
v40mav
Cheers for info
Looks like thats where it's going meantime -
I asked in a well known Car Accessory shop - Don't know was their reply -
I aslo asked if they would make up a smaller plate that would fit on the bumper - even keeping the lettering to the correct size and spacing - - - No - we can't do that was reply.
Will have a look on web later for someplace that will do one - even if it is not 100% surely between that and the one on the roof - PC plod will not have an issue -
[/quote] Defender 110 County SW
Disco 3 HSE
Post #66392 6th Apr 2011 5:17pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Land rover do a genuine bracket so you can mount it to one side of the winch, have a new one for sale
Land Rover Defender Number Plate Bracket 90577143
� 30+ postage to you sir Thumbs Up
Post #66395 6th Apr 2011 5:31pm
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Roof Rack!! Thumbs Up
Post #66409 6th Apr 2011 8:32pm
The Boy
When i have the roof rack on that is where mine is too.
Post #66411 6th Apr 2011 8:40pm
mse
I put mine in front of the fairlead - added advantage of stopping crap going in there.
I have both the one to mount on the top of the bumper and the one to go behind the fairlead and bumper (admitedly missing the clips which i know where to get but never did).
�20+ some postage if you needed - i can supply some pics Mike
Post #66441 6th Apr 2011 10:50pm
TJ101
Mine also lives on the bracket/plate between the fairlead and bumper
Normally held by the half twist button clips,,, !! now double side tape
Mike, as above, do you know were they clips are available from ?? mine got mislaid, between winch swaps !!!
Only quick pic i have,, just make out the tin plate,
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #66445 6th Apr 2011 11:16pm
v40mav
[quote="TJ101"]
Putting on Roof rack just now but would like to have the option of mounting in front of winch and being able to remove quickly when using the winch -
Where can the clips referred to above be purchased ? Defender 110 County SW
Disco 3 HSE
Post #66447 6th Apr 2011 11:26pm
fekete
Just make a bracket in front of the winch for the plate with some quick release pins... something like this
http://cgi.ebay.co.uk/Towing-quick-release..._500wt_922 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #66449 6th Apr 2011 11:36pm
leeds
HOW much?
Search for lynch pin. Should be around 30p each
Brendan
Post #66451 7th Apr 2011 12:10am
