Home > Puma (Tdci) > Complete EGR removal
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
Hi,
I have decided that it's the high time to get rid of the EGR in my 2007 Puma.
I have disconnected the plug from the EGR valve - errors in ECU but no MIL light. Acceptable for now. After I will try to reprogram the ECU.
About the physical removal - I would like to remove this piece of junk completely - the EGR valve and the EGR cooler (it's just occupying space and making access to for example the starter motor worse). I have the blanking plates both for the EGR cooler (3) and the EGR valve (4) but, as I said, I would like to remove it entirely and now the problem of the metal tube (1) with the MAP sensor appears.
Can I buy a blanked tube with the sensor port? I have found some on eBay but without a hole for MAP. Or do I need to cut the original and close it somehow? Also a bypass tube to remove the cooler is necessary.
Is there any complete "removal kit"? Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #708186 20th May 2018 1:16pm
zsd-puma
To remove the cooler just disconnect the coolant hoses and join them together.
For the inlet, it's stainless steel, just cut the pipe off and have someone weld the hole up.
Post #708188 20th May 2018 2:47pm
Bergos
Thank You. Smile
The cutting and welding is what I wanted to avoid... Bergos
Post #708296 21st May 2018 1:32am
HardCharger
Let us know how it all works out and what exactly to do if it does work. Looking to ditch my EGR as well as it's causing more problems than it's worth.
Any drawbacks to this though even if it works?
Post #708298 21st May 2018 5:11am
Bergos
Cannot see any. Just the MOT thing, which in my case is not a case Smile
I've removed the EGR 8 years ago in my D2 Td5. No problems and measured emissions are below spec.
I can see only positives, especially after seeing my intake manifold:
 Bergos
Post #708314 21st May 2018 8:47am
keath
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
Re: Complete EGR removal
[quote="Bergos"Is there any complete "removal kit"?[/quote]
Any luck finding a complete kit Bergos?
Post #743651 3rd Dec 2018 5:20am
Bergos
Yes Smile
EGR-Valve-Round-Cooler-End-Type-Blanking-K...4-3-2-TDCi
Plus a custom made blanking plate for the inlet side.
It's a half-measure as you stay with the blanked, hanging pipe going to the inlet manifold.
Removing the whole EGR cooler and valve took me around 2 hours, on the street in Portuguese sun. Wink
I needed to seal the blanking plates with heat resistant silicone, because they were whistling while driving.
Also... I needed to reprogram the ECU not to lit the Check Engine light after 3 starts. And that was the expensive part... Bergos
Post #758093 12th Feb 2019 2:20am
