![]() | Home > Puma (Tdci) > tickover |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
Any one know how to increase the tick over on the Puma. No doubt it needs plugging into something ?? but is it a Land Rover / Ford only testbook thing or can the aftermarket products do it.
The dpf rattle on tick over I have had for months now is driving me up the wall just a small increase of revs sorts it. If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
probably easier to fix the rattle.
Increasing the idle will also mean the clutch gets a harder life when it's disengaged/reengaged. |
I'm not up for replacing the dpf, engine mount off, breaking rusty turbo studs ect no thanks. Then there is the cost of a new one owch If everything is under control you are not going fast enough.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20951 ![]() ![]() |
There is the cold start thing that sits the revs up about 100RPM, but as far as I am aware is automatically initiated on and turned off by the ECU If and when required.
Best people to advise is tuners, Gary @ Alive or Pete @ BAS. Most of these things are possible, but the long term effect needs to be thought about. Off topic and not applicable to you issue but an example; I'm glad my clutch switch is bypassed, except a totally different thing. Gets rid of that arrigivating increased rpm hunting idle in low range. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
