Home > Td5 > Problem Starting
kweese
Canada 1999 Defender 110 Td5 SW Belize Green
Problem Starting
I recently began having problems starting my car. I just changed the fuel filter valves which did not make a difference. What else can it be? The fuel pump seems to keep pumping and after cranking over for about a minute, it may start. It seems like its taking longer to start everytime. Could it be the Injector seals?
Post #705875 7th May 2018 9:33pm
4RF RDS
Injector seals, check for fuel in your engine oil. You may not find any but depending on mileage changing the seals may be needed. Have you purged the system properly. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #705890 7th May 2018 9:50pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
leaky injector seals are easy to identify... you'll get a fairly large cloud of black smoke out of the back when it does eventually start 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
Post #705914 7th May 2018 10:55pm
kweese
That's what I'm getting!
Post #705923 8th May 2018 1:32am
Maxxed_Ross
fairly easy fix then
Pay the extra for genuine seals. They seem expensive but the quality is worth it Thumbs Up 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
Post #705925 8th May 2018 2:30am
kweese
Do I have to remove the fan and also the rockershaft?
Post #705929 8th May 2018 4:33am
dorsetsmith
Do I have to remove the fan ( yes) so you can get to crank shaft bolt and also the rocker shaft YES
have look at the link below
http://www.discovery2.co.uk/Injector%20Seals.html
Post #705941 8th May 2018 7:36am
