Home > Maintenance & Modifications > Door locks... aaaaaaahhhhhhh!!!!
VVS210
When I bought the DCPU I went mad & bought a load of bits for it, including a genuine replacement ignition lock & 3 matching lock barrels to replace the ones that were not matched to the ignition lock - two front doors & an extra one for the rear door I plan on fitting with a custom canopy.
Anyway, never got round to fitting the new ignition lock back then, but fast forward 12 months & I am getting fed up of not being able to lock the doors on the key so this morning it was time to fit the new ignition lock & then replace the door locks too. For the record, I bought the set from a well respected independent LR specialist after giving them the vehicle reg to make sure I got the right parts - LR077438.
Stripped the dash down & removed the old ignition lock & replaced with new one, all good & pretty hassle free - I even managed to sort out the second remote so now have two working remotes & new keys on the main & spare key rings. Now to the door locks.
Door card off the drivers door first & removed C clip, lock slid out with no hassle, brilliant! Barrel was gummed up with a mixture of dried white grease & mud! Stripped the outer sleeve off & cleaned it then cleaned the crappite out of the door handle itself. All good I went & got the sealed bag with the three new lock barrels in then... Big Cry
The new barrels are not the same as the existing ones & no way will they do the job - Censored !
So, what to do now? - can't return the kit as I have fitted the ignition lock already.
I have the lock number so could order new barrels to match the key, but don't want to do that due to extra cost to me.
Could clean up the old barrels then transplant the tumblers from the new barrel into the old one, lots of faff but would work ultimately, but not keen to do this as the old barrels are full of crappite & corroded too.
Or should I go back to the retailer & curse & swear to no avail as I bought the things over a year ago!
Anyone got a pair of door lock barrels that are in better condition than my old ones that could be used for a transplant?
Post #705457 5th May 2018 4:27pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
I haven't had to do it myself but I believe the end of the old barrel comes off by pressing a pin in the hole you can see. You then swap it to the new barrel.
See here - about 2 minutes in.
https://www.youtube.com/watch?v=PQBM2qjjqCs Dave
Green Goddess - 1998 Defender 110 300tdi
Post #705512 5th May 2018 7:35pm
VVS210
As a 'bush fix' I have swapped the tumblers over from the new barrel into the old one as I wanted to get the lock back in the door this afternoon. I did wonder whether there was a pin to push in but a) everything is crudded up with dry white grease so what looks like a pin wasn't moving & b) everything was crudded up with white grease so it wasn't evident that the barrel could be removed from the end piece. Will have a look again in the morning as it is very easy to remove the barrel from the door handle. If it comes apart then the tumblers will be going back in the new barrel & get used on the passenger door Thumbs Up
Will update once I have done some more investigation!
Post #705542 5th May 2018 9:13pm
NickMc
Yes you depress the brass looking pin and pull the end off and fit it to your new barrels, you’ve not been duped it’s the right part.
Post #705544 5th May 2018 9:19pm
VVS210
Thanks - will see what I can do in the morning. Cheers.
Post #705557 5th May 2018 9:51pm
NickMc
You can’t leave us hanging on like this! Did you get it sorted?
Post #706441 10th May 2018 3:45pm
VVS210
NickMc, sorry for not posting an update, my D4 has died Big Cry so I have had other things to focus on and not yet got around to trying to remove the bit from the end of the lock barrel. If time permits, this will be on my list of things to try and sort out today...
Post #706540 11th May 2018 9:51am
VVS210
Yay!!
After a few squirts of IPA, use of two pin punches & a small hammer I managed to get enough of a gap between the lock barrel & the end piece to get a small screwdriver in & lever the two bits apart.
Result I now have a new lock barrel fitted to the drivers door. Passenger door will get the rebuilt new barrel once I've done that & third barrel will be kept ready for fitting to the rear door later in the summer once the canopy has been fabricated (note I didn't say this summer... Rolling with laughter ).
Thanks to all for their input.
Post #706584 11th May 2018 3:34pm
gilarion
Result , plus you learn something new every day I like you had no idea about that little trick and I also would have thought it was the wrong part. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #706586 11th May 2018 3:40pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
easy mistake and not many people have noticed Laughing
Post #706715 12th May 2018 11:04am
kenzle8a
thought I'd give this a bump as it proved very useful today.
Post #902572 11th May 2021 4:55pm
Kev the Rev
United Kingdom 2007 Defender 90 Puma 2.4 HT Keswick Green
Is it still possible to buy a lock barrel to match your key number?
I don't like carrying loads of keys
It's for a 2007 TDCI if anyone knows the part number
Post #1013978 5th Nov 2023 9:03am
Shafski
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Morning all
I did the same job on mine, just a little late to the party to add help!
You can order one barrel from LR… but.. for literally £15 more, you can get a genuine full lock set. (Note to self it does not include the shear bolts)
As I have read up, the ignition barrel appears to have a shelf life.. I went all out and replaced all. Plus you never know who still holds a key for your car..
(Ok) not that they really need a key.. but you know what I’m saying Laughing Laughing
Great job done btw! Thumbs Up Shafski
_________________________________________
2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E
Post #1013990 5th Nov 2023 10:27am
