Home > Technical > Bouncing speedo needle
22900013A
When I try to cruise at 30mph my speedo needle bounces between 30 up to 40, and the engine sounds as though it is surging slightly, although the rpm needle stays solid. Does this whatever gear I'm in. I know my speedo drive was replaced due to it having a tacho fitted, but it has never done this so badly before. It usually does it after I have a decent run on a motorway then come onto a B road or whatever. The needle goes back to normal as soon as I accelerate up to 40, 50 or whatever.
Any ideas? 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #704555 1st May 2018 3:08pm
rallysteve
I presume this is your 2011 puma engined vehicle?
If so there shouldnt be any bounce with it being electrical. I would suggest a few simple checks if your noticing the sound of the engine surging as well. I would first advise checking your propshaft UJs are in good condition and that the UJ yokes are correctly lined up with each other at both ends of each shaft.
Post #704565 1st May 2018 4:14pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
With my 200tdi old school speedo it does the same. I'm convinced that it's got a kink in the cable somewhere.
Post #704566 1st May 2018 4:14pm
22900013A
Yes it is my 2011 Puma. There is definitely a bounce, if it is electrically driven then obviously the impulses are somehow out of kilter. The surging is very subtle and only happens when the speedo is bouncing, the vehicle does not move any faster and the rev counter remains solid, but it is as though power is coming on and off very slightly. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #704622 1st May 2018 8:31pm
zsd-puma
Where does it pick up the speed pulse?
It'll either be a mechanically driven sender unit on the gearbox or it'll pick up the signal from an ABS sensor. Either can go faulty. Damaged wiring could also do it.
Post #704664 1st May 2018 9:51pm
22900013A
I believe it os off the gearbox but electronic or at least electro-mechanical. The pick up was replaced as part of the tacho installation, I still have the original one somewhere. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #704938 3rd May 2018 7:06am
marcoegyptos
France
Hi
I have almost the same problem , I didn't solve until now as I am out of home from several months. I change already the speed sensor ., no result .
When I start the car , I don't have any problem with intermittent inductive load (AC & wiper) but when the battery is fully loaded the problem appear , that means when I have inductive load open , those create a surge it's look like a load dump , . Should it be a bad ground ? may be in the C0550 connector . I should investigate deeply as in this condition the car is not drivable.
Any idea is welcome ?
Post #705108 3rd May 2018 9:32pm
22900013A
That ^^^ sounds horribly complicated.
I did notice on mine that there is no problem until the engine is thoroughly warmed up. I can't help think something is getting hot somewhere. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #705385 5th May 2018 8:39am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Have a look where your original sensor would be and there might be a short cable that goes to a tachograph kitas sender. The cables are prone for plying up and eventually snapping.
will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #705468 5th May 2018 5:32pm
22900013A
Where do I need to be looking? And why does it only happen at certain speeds and once everything is warmed up?
I did some testing today. After first setting off everything is fine. 25 miles up the motorway, turn off and the needle is up and down like a yo-yo, reading 40-50 when doing 30. Definite "on-off" feel of power through the engine, but rev counter remains static.
Coming home, I found if I cruise at 20mph there is a very slight wobble from the needle, cruise at 40 and it is fine. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #705546 5th May 2018 9:30pm
jackbuchan4x4
United Kingdom 2016 Defender 110 Puma 2.2 CSW Corris Grey
Same Issue- Speedo Needle Jumping- Defender 2.2 Puma 2016
Good Morning,
I have the same issue on one of our 2016 Defender PUMA 2.2 Litre
Do you have any update did you manage to get to the bottom of this issue?
Hope to hear from you soon!
Jack Buchan
4x4 Hire (Scotland) Ltd
jack@4x4hirescotland.com
Tel: 07711-329631
Post #793951 19th Sep 2019 11:30am
