Home > Off Topic > It really pays to complain...
gilarion
I am not usually one to complain however recently I bought four shaker cans of Hammerite satin black and even though after using I turned the can upside down and sprayed for a couple of seconds and even took the nozzle off and cleaned in thinners the next time I used them they were blocked, and nothing would make them discharge paint it was the valve in the can that was the problem.
So I decided to complain and sent this email
Hi Hammerite
Could you please inform me how to keep a can of Hammerite satin black spray active? No, matter what I try such as inverting the can and spraying to clear the nozzle before storing the can, I end up with a blocked spray can that will no longer discharge a spray. I keep the cans indoors and clean the nozzle after each spray use. It appears with some of your cans it is the valve that blocks. At present, I have four cans that are over half full that are useless. I do not have this problem with other spray cans just Hammerite cans. It is annoying as each time I wish to finish a project I end up having to go out and buy a new can.
Any advice to unblock the ones I have or any tips would be gratefully received.
Kind Regards
This was Hammerites response:
Thank you for your email. I am sorry to hear of the problems you are experiencing with the Hammerite spray cans. I have logged this under reference number 3000253406 if you can please use this for future correspondence.
This problem commonly occurs due to a build-up of solvent in storage. It is important to ensure the nozzle is cleaned thoroughly and the cans are stored in a cool, dry environment. You can also use a needle to release the pressure from the tip of the nozzle.
As a gesture of goodwill, I would be more than happy to replace the cans for you. I will require the following:
-Barcode from can- this will be on the back of the can beginning with 5010
-Full UK postal address
If you have any further queries, please feel free to contact me and I will be happy to help.
Yours sincerely
Hayley Weller
Customer Advisor
AkzoNobel Advice Centre
AkzoNobel
ICI Paints,
Wexham Road,
Slough,
Berkshire,
SL2 5DS,
Phone: 0333 222 7171 (DIY advice)
0333 222 7070 (Trade advice)
And today I received a voucher for the four cans. Good one Hammerite Thumbs Up Thumbs Up For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #703338 26th Apr 2018 5:21pm
JOW240725
Result! James
Instagram @suffolk_rovers
Post #703354 26th Apr 2018 6:37pm
Procta
Hammerite I found doesn't seem to go the distance for me. With in a few weeks everything just back to been rusty again. Sad Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #703404 26th Apr 2018 9:21pm
