Home > Technical > Machine gun knocking noise from the rear!!! |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Hand Brake, yes I know the've adjusted it but probably not correctly or when it was hot.. Usually happens on longer journeys Original Member Pie n Pea Club.
110 HCPU Tipper |
29th Mar 2011 12:57pm |
Blaserman Member Since: 23 Sep 2008 Location: Herefordshire Posts: 46 |
Even if there is no movement in the handbrake itself when applied lightly? only seem to do it after about 20 miles.
29th Mar 2011 1:00pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
I'm thinking along the same lines Pete, Remember there was a run of oval drums a few years back. The drums would get hot and 'pick up' on the shoes.
Rob take it up the road allow it to make the noise for a bit then stop, get underneath touch the brake drum, if you smell burning skin and your fingers hurt this could be the issue. Oh do this in a safe place so you don't hurt yourself. 130's have feeling's as well you know |
29th Mar 2011 1:11pm |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 |
My Feb 60 plate Ute was EXACTLY the same. They backed off the handbrake a couple of clicks and hey presto. Ludicrously fine tolerances. D300 HSE 110
29th Mar 2011 1:50pm |
WOW Bet that phrase has never been used before on a Land Rover forum 130's have feeling's as well you know |
29th Mar 2011 2:40pm |
A new hand brake drum is on order!!!
cheers guys, I wish they did use fine tolerances especially when putting the body together, it would make moding a bit easier! |
29th Mar 2011 2:50pm |
You going up the Red Later? 130's have feeling's as well you know
29th Mar 2011 2:56pm |
Would be rude not to. What sort of time mate?
29th Mar 2011 3:39pm |
5 Oclock club If I can hold out till then Fooking Customers 130's have feeling's as well you know
29th Mar 2011 3:48pm |
Well jealous Original Member Pie n Pea Club.
110 HCPU Tipper |
29th Mar 2011 4:04pm |
29th Mar 2011 4:06pm |
That will be the hand brake drum (oval) and the REAR DIFF!!!! Its only 7 weeks old and being used on tarmac FFS! Cant wait to see how it holds up when it starts to get some abuse!
31st Mar 2011 12:32pm |
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 |
I've had a new transmission brake drum - made no difference. Then some adjustment of the hand-brake shoes in the winter when it was clattering all the time -improved for a while, but the problem is returning (warmer weather). If there was a bit less play in the rear diff... 1953 80
1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
31st Mar 2011 5:53pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
Would a disc handbrake help? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
31st Mar 2011 6:37pm |
