Home > Maintenance & Modifications > another headling question
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
i was thinking of covering my headling as it is getting a bit grubby, i was lloking at headliner material and thought about trying it myself, has anyone done this do you stick it direct onto the existing lining or remove the existing cover back to the card base, any input appreciated nobody is perfect but being Scottish is a start
Post #703283 26th Apr 2018 12:06pm
gilarion
You need to remove the original fabric and any sponge that it left stuck to the card. Then use a spray glue to stick the new covering. There is a member on here who sells the original OEM fabric Ibexman on this forum sells it. Fabric is 1.2 wide 12 metre plus p&p. PM him your requirements I think his phone number is. 07944349763 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #703285 26th Apr 2018 12:33pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
When i did mine the original was peeled off, the liner sprayed with high temperature caravan glue then stuck on some Gortex black fabric.
Once in a rough shape I folded the edges back and stapled them down and glued the edges as per the original
Looks excellent, was really easy to do and best of all is now wipe clean!
Post #703374 26th Apr 2018 7:45pm
T140
thanks for the replies, i was thinking of doing it black i have seen headlining material on the net at a reasonable price. nobody is perfect but being Scottish is a start
Post #703484 27th Apr 2018 8:44am
steveyorks
England 1993 Defender 90 200 Tdi CSW Barolo Black
Note the use of high temp glue! It really makes a difference as if you use something else like Evostick it falls down after a few weeks even in winter.
Post #703590 27th Apr 2018 5:08pm
