Home > Maintenance & Modifications > Exhaust mot and road legal spec please ?
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all,
Without giving away my cunning plan just yet Whistle
What is the above requirements for say a 90 exhaust please?
Mainly where can it exit from the car, noise protrusions etc ?
Many thanks in advance, if I go ahead I shall pop some pics up when done Thumbs Up
This is my last "one off bit" before I finish selling up my gear Crying or Very sad
Post #702915 24th Apr 2018 7:41pm
bankz5152
Depends on year. Pre 2000ish nothing just do what you want really. Post 2000ish should have a cat if fitted from factory but many are decatted and passed MOTs fine (my two have no problems). 2007+ needs a DPF (and cat I think)
Side exits are fine too just can't be a sharp edge sticking out.
Post #702921 24th Apr 2018 8:02pm
DPF only needed on approx 2012 > 2.2 Defenders as fitted by the factory. CAT should be present on all engines. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #702925 24th Apr 2018 8:10pm
discomog
As long as it exits after the DPF and Cat it should be ok. I'm sure there are regulations which limit how far it protrudes from the body. Check with the guy who normally does your MOT Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #702929 24th Apr 2018 8:33pm
Daisy90
Thanks guys, its a TD5 and pre cat , so looks like the only issue i may have is reducing the noise level,
Ill get thinking and scetching away,
Watch this space Wink
Post #702994 25th Apr 2018 5:57am
bankz5152
Still ahould be fine, my old 90 mpassed its MOT with zero boxes. I eventually put the rear most box back on as was too loud on the mway
Post #702998 25th Apr 2018 6:25am
