|  | Home > Technical > Difference between ABS and non-ABS axles |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | So is it reasonable to assume that a non-ABS axle can be converted to an ABS axle by simply fitting an ABS upper swivel king pin (the type with the hole for the ABS sensor) and an ABS sensor?
 yes   Click image to enlarge ABS reluctor ring is machined into the CV Last edited by dorsetsmith on 24th Apr 2018 8:01am. Edited 3 times in total | ||
|  24th Apr 2018 7:55am |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363      | Sound, thank you   | ||
|  24th Apr 2018 7:59am |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039      | Without abs CV's are stronger.
   Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) | ||
|  24th Apr 2018 10:41am |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363      | Roel, that must be a pre 2007 non Puma CV? | ||
|  24th Apr 2018 10:47am |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039      | Yep td5, but are they different except for the abs? My td5 doesn't have abs so I don't need the cut outs.
 My experiences: ABS CV:   Click image to enlarge Non ABS CV:   Click image to enlarge With the none ABS only the internal break. But now I have Aschroft front and rear. Yep it is an investment, but if they give 5 year waranty with 35" tyres that I use I am sure they will be OK. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) | ||
|  24th Apr 2018 12:45pm |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363      | Further to this, I removed the upper king pins from a Puma axle to find non-ABS shafts...
 So don't assume all Puma axles have ABS type shafts! | ||
|  27th Apr 2018 10:10am |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | on 07 Puma LRJ may have been using up none abs axle from stock | ||
|  27th Apr 2018 11:12am |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363      | It is an early Puma axle so quite possible | ||
|  27th Apr 2018 11:41am |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
