Home > Maintenance & Modifications > New Door Hinges
mpald
United Kingdom 2004 Defender 90 Td5 HT Keswick Green
New Door Hinges
I have finally reached a level of irritation which requires that the driver's door hinges need to be replaced; I do not intend to sell either or both of my kidneys to fund Cryotec's beautiful craftsmanship! Does anyone have any experience of the PowerfulUk hinges at the following:
https://www.powerfuluk.com/vehicles/land-r...ushed.html
Or do you think I may be better off getting some galvanised hinges paint matched? Any recommendations would be much appreciated.
Post #700758 14th Apr 2018 2:17pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi mpaid, have you had a look at Optimill or Gore products, good stuff Thumbs Up Cogito ergo sum
Post #700820 14th Apr 2018 7:00pm
Sulisuli
Had a chance to look at Roy5695 Defender today and he has the Optimill hinges and handles fitted very nice indeed and high quality as you would expect from Optimill Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #700846 14th Apr 2018 9:01pm
L110CDL
http://www.defender2.net/forum/topic60471.html Whistle Clayton.
Keeper.
Post #701384 16th Apr 2018 9:44pm
mpald
Thank you all for your advice; in the end, I went for the PowerfulUK hinges in brushed stainless steel. They were significantly cheaper than Optimil - I'll see if they are as good!
Post #703999 29th Apr 2018 5:10pm
Chocolate
United Kingdom 2004 Defender 110 Td5 XS CSW Bonatti Grey
hi mplad,
Did you get the powerfuluk hinges? Are they good?
I have the same dilemma with my front hinges. 110XS CSW TD5.
Post #721779 6th Aug 2018 6:31pm
gilarion
Its a small world as today I fitted those exact hinges. The profile of the hinges is the same as OEM ones so look like the originals.
Because they have the same profile if your door was sprayed with the hinges affixed (which Land Rover always did) these hinges will fit exactly on the paint line so no lines of primer showing as with some of the other stainless hinges.
Excellent quality well machined and easy to fit even comes with new gaskets and stainless steel fixing. Each hinge comes well protected in packaging. If you buy these hinges you will not be disappointed the brushed finish is less in your face than the highly polished versions. Just fit one hinge at a time to keep the door alignment correct.
Tip if the captive nuts in the door A-frame pillar are Ok then leave them rather than replace as they are a Censored to fit and you usually end up dropping one down the pillar.
Just need to clean off the grease and copper slip off the door pillar and mirror arms and the jobs a good un!
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #721787 6th Aug 2018 6:52pm
Caterham
I didn't know that - stainless steel alloy?
I thought it was one or the other - a mix of metals being an alloy? Confused I know the above seems petty but I'm curious Thumbs Up
look nice by the way.
Post #721799 6th Aug 2018 7:29pm
gilarion
Stainless steel is an alloy of Iron with a minimum of 10.5% Chromium. ... Stainless steel also contains varying amounts of Carbon, Silicon and Manganese. Other elements such as Nickel and Molybdenum may be added to impart other useful properties such as enhanced formability and increased corrosion resistance. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #721810 6th Aug 2018 8:06pm
Chocolate
Thanks gilarion.
They look great. Was looking at the brushed versions today.
Will have to bite the bullet. Thumbs Up 110XS CSW TD5.
Post #721827 6th Aug 2018 9:18pm
